Annoyance: auto dimming high beams only start at 40 mph?
Spectordog
Ari
New Hope, PA
Audi Q5e, Macan 4
Has anyone else encountered this? I live on curvy, dark country roads with speed limits well below 40mph and this is when I need this feature most! Does Porsche do this on other models or only Macan EVs? ( new Macan 4 in USA.)
Same on all Porsches.
So can't you leave your brights always on??
Spectordog
Ari
New Hope, PA
Audi Q5e, Macan 4
Yes, of course, but you must toggle them off every time a car approaches from opposite side, which is the point of auto dimming.
i think this is one of the features that are NOT enabled for the US market right?
Dragon Tourniquet
Chris
Nevada
BMW iX
Auto high beams are pretty common, and I believe I saw it in the US manual.
Adaptive High Beams are what generally isn't available in the US because DOT / NHTSA made the technical requirements for it much tighter than what Europe uses. Why use something that has worked well somewhere for a decade and is still faster to make adjustments than a human when you could mandate something even better and delay the rollout by years?
PDLS+ (auto beam) is standard and Matrix SD / HD enhances this except if you live in NA.
Unfortunately I can confirm that also Matrix system works only when you exceed the 60 km/h. Not so nice when you live on the mountain and in the first 20 km you drive every morning (early in the morning) the longest straight is 50 meters long....
Likewise, you have to accelerate to activate it, and then you can slow down and it remains activated.
60 km/h is too much compared to other brands.
Agree, it should really get activated at 20MPH (33 km/h).
It's good to know that once activated at 60 km/h, it remains active at lower speed.
Boston, USA
Mini SE
Yes, annoying I think most if all other brands work the same way. I also don't like how light reflected from road signs can switch to low beams. I haven't used auto high beams in years because of that. Same with the side turn lighting, always turns off when most inconvenient. I dunno of any brands where these are user configurable, must be regulated in most countries.
With matrix headlights, there is no such ”turn off” because of reflected road sign: the leds which correspond turn off, but the others stay on.
the Only issue is this speed related activation… and maybe some reflection under heavy smog/rain/snow.
Unless you encounter street lighting wherein which case the lights will dip
