Bose sound stopped working
None of my Bose speakers were working using any media when I got in my car to drive home today. Tried to make a tighter connection on the Bose plug under the trunk but still didn’t work. Locked the car and when I returned about 10 minutes later the speakers were working.
I didn’t reboot the PCM but I guess turning the car off and leaving it for a few minutes reset the speakers. Not sure if fiddling with the Bose plug really helped or not.
Nope, no need to fiddle with the plugs.
Happened to me a couple times, same lock-the-car-wait-a-bit steps worked, just one of those gremlins.
bbmertz
Glad to know I’m not alone. Btw, this speaker gremlin is not unique to Porsche EVs since my wife has the same issue/fix in her Ford F-150.
Had this gremlin more than once (no sound, sound only on the left side, sound only in the front speakers) and found out that disconnecting the sub connector in the trunk, count 10 to 0 is faster than closing the car and wait. Just my 2c. About this it reminds me my previous Tesla M3LR when the infotainment showed a problem every week (even if with it a simply reboot of the PCM solved the problem without stopping). It's time for an update of the PCM, come on Porsche :p:p:p
Frenchboy
Nico
Seattle, WA
2025 Macan Turbo, 2018 991.2 GT3
That just happened to me as well this morning. No sound at all from any speaker. Somehow I was able to make a call and sound came through. Waiting an hour or so and it is back. Weird.
Car is 4 days old :-(
seabird
Earth
Macan 4S, Audi RS5
I don't think there's much Porsche can do about it. The Android audio stack is pretty limited and buggy. Maybe there's a Porsche-specific bug in there somewhere, but this type of complaint seems to be in the forums for basically all AAOS cars.
Have definitely seen it on Rivian and Polestar, and others have called out Ford and GM products as well.
Daniel
Europe
Sold:Taycan 4, Now Macan 4
No luck for me, after several reboots, PCM reset, factory reset, connector on-off, no more Bose... nor sound setting menu for a week.
An appointment has been made for next week with my dealer, who will take the opportunity to do the "major ?" update, update which according to him will solve this problem.
Slater22
Matthew
This just happened to me, no sound at all, drove home, tried to disconnect to one in the boot, no luck. Left for 30 mins and now back on. Just 2 weeks old. Hopefully a one off.
Aiwendil
WI
24 Macan 4
This has happened to me twice now. Each time, the symptoms are specifically that music doesn't work. Only music and music in every flavor (radio, CarPlay, non Car Play integrations) does not work.
Also, both times I have had this happen, I get the "Component Protection Active" error message when the car starts. In both times, it starts with "lock car, walk away" being a solution that works, then steadily worsens until nothing but a dealer appointment resolves the issue.
Here's what I have tried latest round:
-Reset with volume button held in for 30 seconds
- Disconnect/reconnect Subwoofer plug
Is there anything else I should try? A factory reset? Disconnect battery terminal?
This is incredibly frustrating as there appears otherwise to be nothing wrong with the vehicle. So I am driving around in a $100k car with a bluetooth speaker on the passenger seat while I await my appt because "component protection active" whatever TF that means.
Porsche has a software quality problem, and it is not getting better. This is worse than my Taycan ever was and that was the platform where they were presumably working out the bugs. Just because Tesla rolls with the "we launch garbage, and bugfix our way out of it with 'continuous improvement'" doesn't give a brand like Porsche permission to do the same. Owners should spend zero time even thinking about the software that powers their vehicle
Aiwendil
WI
24 Macan 4
Is that the recall? If so, I've not yet taken in for the recall, recall service will be done at the same time as this.
Daniel
Europe
Last recall service ,done at the same time, solved the problem for me.
Complete sound system was off, no more Bose menu, an Android bug (i had a very short error message , one time).
tonyadduci
tony
chicago, il
porsche macan ev turbo
this occurs frequently for me. noticed that it occurs more frequently when you turn off the radio while driving for any reason and then power back on. the system has a "dvr" for the radio and it seems to cut out when recording more often then when you are simply playing content back live.
resetting the pcm works every time.
TWHMan
Kent, UK
Macan4 EV
Ended up resolving the issue by itself and had the sound again after parked and locked for a few hours.
Yes, my Bose had no sound. The sound progress bar would not show when I turn up/down the dial in the central console or on the steering wheel. Even system sounds like indicator or audible speed warning would not come on. Locking the vehicle and coming back to start the car sorted out. Feel like I am driving a laptop. :)
there seem to be 2 different problems with bose: the connector made some problems in the first cars of 24 and porsche had a fix for this. possible that this problem is popping up on later cars too.
and after the software update i had 3 times complete loss of the bose, but phone still working. it fixed itself switching off / on the car.
plan to have it fixed when next software upgrade is due in feb.
Flying4Fun
Has there been any updates or reports of people having this solved (long term). I am getting this about 1 or 2 times per month. and I have all the updates done. I did have a defective 'assist module' that was showing with a voltage defect when tested, when replaced, reported correct and the car seems to not have had asisst issue. The defect was detected on the communciations between the gateway module and assist module.
With that, I have been having the Bose audio issue where the PCM looks like everything is working, Metadata, volume control, source changes - literally all indications look like its working, but there is no audio from any source. Parking the car, locked, and returning later does seem to 'self-correct' it.
Reviewing with thread history is appears to be the same issue, but this thread dates back a Long time.
Is this still happening for people? has anyone had an action taken and it has resolved the issue (if so what action).
thanks
