- First Name
- Diego
- May 12, 2024
- Italy
- Macan 4
If it would be helpful, I would like to collect in this discussion records of problems described by users up to the date given in the title:
Please consider this thread as a glossary thread, which links to individual reported issue threads (where everyone can reply and comment). If you have an issue, please create a new discussion thread for it and it will be added to this list.
Area / thread link | Issue | Region | User | Cause | Fix |
Air Conditioning | no cooling is provided. | US | No freon installed | ||
Air Conditiong / vents | passenger side floor vent / flapper doesn't close | US | TBD | Loose connection fixed, solved | |
Climate Control Button | button intermittently don't work when the car is powered ON | US | TBD | ||
Satellite Radio | connection lost | US | TBD | Not a recurring issue. | |
Electric charger port cover | passenger port works randomly | US | Sensor out of position | ||
Owner's Manual in PCM | No Contents are available in PCM | US | TBD | ||
Instrument Cluster | instrument cluster does not turn on (display blank / dark) | Canada | @dmd | TBD | |
Blind Spot Monitoring | Blind Spot Monitoring not working | US | TBD | ||
Assistance Systems Error - Speed Limit Display (Warning Message) | Intermittent fault messages displayed on instrument cluster | UK | TBD | ||
Assistance Systems Error - Speed Limit Display (Warning Message) | Adaptive cruise went out | US | TBD | ||
Loud buzzing sound from mirror area | After triggering the front collision warning system there's a loud buzzing sound coming from the upper mirror area (cameras/sensors just below the mirror) getting worse pressing the plastic cover | EU | TBD | Car restart solved | |
Front (air) suspension cracking | Cracking sound from front (air) suspension when driving slowly over speed bumps | EU | TBD | ||
DC Charging Issue Due to Software Glitch | DC charge at an Electrify America terminal - no success. | US | software glitch | ||
Bose sound stopped working | Only two front speakers works no matter what I do, reset pcm | EU | TBD | ||
Compass intermittent function | sometimes compass works properly and sometimes it does not | US | @dieterf | TBD | |
Trunk emergency release error | Vehicle sounded alarm and displayed warning message while parked in garage | Canada | @shawn | Unknown | Alarm stopped on its own after 10 minutes and trunk operation is normal |
Smoke and burning smell from air vents | Burning smell and smoke from air vents when driving 130 km/h (80 mph) or higher, with or without the climate control on | EU | @piter95 | TBD | |
Rotating Random Sensor Alerts | Series of rotating random alerts that keep cycling | US | @GaryV | TBD | |
Charge Port | Charge port doors can open on their own in automated car washes | US/CAN | @daveo4EV | TBD | |
Charge rate | It appears North American Macan's are capped at 40 amp charge rate and not the 11 kW (48 amps). | US | @daveo4EV | TBD |
