Porsche Electric Sport Sound always defaults to OFF
Briboynyc
Brian
Dallas
So I'm brand new to the Macan EV and I got the car with the Electric Sport Sound. Every time I get into the car the electric sound is off. I toggle the button on. Next time I get back into the car it's off. Not sure why it keeps disabling every time I start driving again. Anyone else ever experience this? If so is there a fix for this? Its annoying paying for a feature that doesn't work.
wmras
Bill
Oregon
It may stay on if you set it ON in the PCM display (Normal Configuration). This has worked for us in the past, but it recently stopped, and I have not tried to reset it.
We have Electric Sound on in the Sport Mode (settings stick) and that is the mode we normally use.
As a side note, recently had a woman in the back seat comment she liked the sound (Macan Turbo). I personally like it better than our Taycan Turbo S.
This is how Porsche has designed it to work on all cars including ICE. Electric Sport Sound or Sport Exhaust Sound must be turned on manually or assigned to a driving mode that is not a default Normal mode.
bbmertz
Yeah, that’s the main reason I didn’t include it in my build. I rarely use Sport mode and wasn’t likely to manually turn on the sound every time I drove.
Briboynyc
Brian
Dallas
I went into drive mode. Changed it to sport plus. Hit the check mark button and the car still reverts back to no sports sound and it didnt stay in sport plus
Yes, that is by design. The car always starts in Normal to which you cannot assign Sport Sound On.
The point we are trying to make is that you have to either turn it on manually when in Normal or you have to flip it to Sport or Sport Plus with Sport Sound On setting saved in these modes.
Briboynyc
Brian
Dallas
Ok Thank you! Thats kinda stupid you cannot set sport or sport plus
RGBArgee
Rick
Somerset and Brittany
I specified sound on my previous Taycans but Macan came without it - can’t say I’ve missed it but surely all EVs should have a noise below 20mph for safety??
Wrighty
Yorkshire
Wrighty
Yorkshire
I was just about to ask precisely the same question then came across your thread. It's utterly stupid of Porsche to force drivers to turn this function on every time they get into the car. I'm the same as you - I clearly bought this feature because I wanted the sound. So why on earth has Porsche assumed that anyone buying this 'optional' feature would then want it turned OFF by default! It makes no sense at all.
I very much hope this oversight will be fixed in a software update.
Station
CO, USA
Sport Sound (Electric Sport Sound) will always turn itself off. It's another silly decision by Porsche. As mentioned you can assign the ESS to the button on your steering wheel but that's not the best solution because you may want something more important assigned to that "fav" button.
Headscratcher. Come on Porsche!
atebit
PA
Macan 4, Macan 4S
My (still ICE, unfortunately) 718 defaults to the annoying “motor stop” mode, which shuts off the engine every time you stop at an intersection, etc. Same thing, even if you disable it, the next time you start the car it defaults to “on”.
But, I was able to install this “memory module” unit that remembers this & some other non-persistent settings across drives. I wonder if there is or will be such a dongle for the Macan S?
ron_b
Ron
California Central Coast, USA
I too wish that Porsche would allow saved alterations to the normal mode, but I can understand their thinking as well that the key-on settings are consistent for all cars, not that you could put it into low suspension with key-on or such. This also means that the ESS cannot be automatically enabled on key-on.
I would say, if you like normal mode, then assign it to the joker key on the steering wheel.
For me, I would only use the sports sound in Sport mode on my Taycan. So that’s easily saved in that mode with the new PCM. The Taycan would only automatically enable ESS with Sport+.
