Sharing Exp- installed BLACKVUE DASHCAM – DR970X-2CH LTE
someTimesJoe
Joseph
Tri Valley, Ca
Taycan CT 4S, Macan EV 4S
That looks good and clean!
Didn’t realize that there was that much room for the box. I ended up putting my own air compressor and tools in that spot.
More room in the Taycan and should have swapped the box setup from the Taycan to the Macan and used the full DR970 instead.
someTimesJoe
Joseph
Tri Valley, Ca
Anyone using ODBC port as power? I have it for power for the last 3 months but seems like a recent firmware update, it sleeps now when parked. DR970X -2CH setup and working totally fine and using the Macan’s hotspot while driving. When you get in the car, it gets out of sleep and starts recording. Before all of this, you can see the LED status lights and when it detected motion, it’d blink. I’ve tried turning off the low voltage cutoff and then keeping it on but lowering the threshold to the lowest it’ll let me.
Curious if anyone else seen this?
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
i use the obd port and it works fine but i dont have that cam model i use the 3ch 770x box pro.
TaycanEagle
Biron
Texas
Macan 4, Taycan 4s
I had great success with the BlackVue 970x LTE Plus. Initially, we hardwired the setup, and I found the parking mode feature very accurate. I never worried about draining the 12v battery because of the voltage cutoff capabilities. However, a few months later, I added the blackbattery to increase the camera’s operating time when parking for extended periods. So far, I’ve managed to go 15-18 hours in parking mode with the BlackVue battery having about 80% charge. I’m impressed with the app, camera quality, alerts, and the ability to customize modes.
bbmertz
Has anyone installed the Blackvue Elite 8 in the Macan EV? I’m interested in purchasing the new Elite 9 which is about to be released but heard that the Elite series may not work in parking mode if hardwired into the fuse box as the fuses provide constant power and that installation may void the vehicle warranty.
BigApple
Andreas
NJ
not sure if this applies to everyone but i now feel i no longer need the additional B130 battery.
There was a new update applied for my car at the dealership. And now the High Voltage battery maintains the 12V battery. It didn't do that before. I have been monitoring it for the last month. and my 12V car battery does no longer go below 11.7V . So no longer need the extra Dashcam battery it seems.
Anyway to confirm that? As far as I know, when the car is off the high voltage battery stops charging the 12v battery.
Where did you place the battery and how did you handle the wire connection? I was thinking of placing it to the left of the subwoofer under the trunk’s floor.
BigApple
Andreas
NJ
yes that is how it used to be for me. My Tech Rep mentioned that there was an update and it sounded it was across the entire line of machans. Although i must say that i went to Stuttgart to talk to some folks at the Department where they developed the car. I told them my problem, and they said they will look into it to fix it. Maybe they have. But it sounded it was for all of them.
BigApple
Andreas
NJ
yes that is where i have it. also. I did add a hardware voltage drop switch . to prevent it from draining the 12V battery beyond 11.5V. Want to make sure the car does not go fully dead. But now it seems i no longer need all that.
ADS
Alexander
Berkshires, MA
Macan 4 EV
Does anyone know if the Porsche hotspot can be used to drive the Blackvue Elite 9?
BigApple
Andreas
NJ
it is tricky as it seems the hotspot has to be turn on and off(reset) each time you start the car.
At least that is how it is on my car. it may connect to the SSID but the internet backend needs to be reset. (My personal experience)
BigApple
Andreas
NJ
Bummer, thanks.
but it can be used .... just not as easy as with other hotspots. I use the LTE Module and it works fine.
ADS
Alexander
Berkshires, MA
Macan 4 EV
Well I was hoping to use the hotspot for the cloud...
