![United-Kingdom Country flag](https://www.macanevowners.com/forum/misc/flags/shiny/32/United-Kingdom.png)
So 4S seems to be the sweet spot for spec, value and power.
Yup. I'd encourage anyone to go test a Taycan 4S vs Turbo if they're wondering about power or a Taycan 4S vs an iPace/CT4 to compare the 4 vs 4S.So 4S seems to be the sweet spot for spec, value and power.
In my case, it’s only $8k difference between the 4S and Turbo… not sure it’s worth the downgrade.I just spec’d out a very nearly identical 4S Macan to a turbo. By the time I added in the different options that are standard on the turbo but not the 4S, yet keeping all other options the same, the turbo was $10,000 US more. I doubt that anyone doing the same would not find a very different amount, due mostly of course by the higher same-option price on the 4S and compounded in my case since I have lots of options. Still $10K is a large amount and as posted above, the 4S will be the sweet spot for many.
Guessing that for some that difference would be way, way closer to the $20,400 no-option MSRP’s.
My original Turbo spec is fairly heavily loaded with options so when I build a 4S to pick up all of the standard equipment of the Turbo plus match the options, the difference is just over $4k Canadian dollars. Maybe I've made a mistake. Here are the codes if anyone is interested:I just spec’d out a very nearly identical 4S Macan to a turbo. By the time I added in the different options that are standard on the turbo but not the 4S, yet keeping all other options the same, the turbo was $10,000 US more. I doubt that anyone doing the same would not find a very different amount, due mostly of course by the higher same-option price on the 4S and compounded in my case since I have lots of options. Still $10K is a large amount and as posted above, the 4S will be the sweet spot for many.
I would not downgrade….In my case, it’s only $8k difference between the 4S and Turbo… not sure it’s worth the downgrade.
Spent some time reviewing both trims and agreed, the outside of the Turbo (especially the front) looks much better I find. And being able to paint the lower rear fascia is nice too!I would not downgrade….
My Turbo build is about 10k close to a comparable 4S build, but you have a remarkable extra of power (think my Taycan 4S pre Facelift is very close to a Macan 4S) and the exterior looks different (imho better).
so my two cent: upgrade from a Macan 4: yes, downgrade from turbo: no
YMMDTerribly or truly terribly?![]()
Same for me. Frozen and ordered. Re-specking my 4 into a S means a marked up price of € 5,680. Nevertheles, the 20” wheels are free. I would have chosen them because they are the same as my Taycan wheels. There was no choice for decent 20” wheels on the 4 except the ugly ones. Without the 21” wheels, the difference is only € 3,470… I would have chosen the S but it’s too late now…If I re-spec my MY24 Macan 4 (ordered and frozen) into MY25 Macan 4S here in Norway - I got a markup of approx. of USD 8,100 / EUR 7,400.
And that's w/o the PTV+ I kindof really wanted (N/A on Macan 4), i.e. an additional add-on for the 4S of USD 1,700 / EUR 1,550. So I guess I'm still quite pleased with my current 4 order.![]()
The RWD is a bad choice for you, get a 4 or 4S. Period. You lose more than you'd think going to the RWD and it's an SUV that will be surprisingly capable with AWD.I had plans for a Macan 4 but am now wondering if a more simple RWD Macan with a few extra options wouldn't be a better choice. Even though I live in Switzerland, occasionally (rarely) driving on snowy mountain roads, 4 winter tires + proper traction control should do the trick. I don't care for extra torque / hp.
What do you think? Should a Porsche be RWD? but a Porsche Macan AWD?
There is certainly an element of truth to your thoughts, but there are some advantages of the RWD:The RWD is a bad choice for you, get a 4 or 4S. Period. You lose more than you'd think going to the RWD and it's an SUV that will be surprisingly capable with AWD.
I'm a huge proponent of "if there could ever be a time when you wish you had AWD. get AWD" for safety, if nothing else. Not only snow but you're driving through the mountains and hit rain? Gravel on the road? Suddenly find yourself on a steep dirt road? Etc. Sure, RWD is probably fine but the peace of mind is worth it.
