Under Door Puddle Lights
Newbie question please if one does not choose this option, are they any basic lights that shine down on the pavement when one uses the key fob to proximity unlock the car, or whether without the option there is total darkness until one opens the door itself, e..g, a safety question of whether there is no pavement lighting at all unless the “Porsche” puddle lighting option is chosen? TU
Please. Anyone know the answer? TU
As far as I know, zero light unless you have the puddle - or open the door.
Using the key fob to unlock the car should trigger the hazard lights if like on the Taycan (and most cars).
Thanks much.
Mike in CA
Mike
North Bay Area CA
2021 Taycan 4S, 2019 e-Tron, GMC 2500HD Duramax
Assuming I understand your question correctly and that the lighting features in the Macan E are similar to the ICE Macan, the "Porsche" puddle lighting element is located in the underside of the door so there is no light unless the door is open anyway. Once the door is open there is a marker light in the door for warning approaching drivers and it provides plenty of light to see the ground. IMO, the "Porsche" light is an unnecessary gimmick.
Interesting. In some other cars (like the Mach-e for instance), the puddle light turns on when you unlock the car with the fob - as well as when you open the door.
ThomasDK
Thomas
Denmark
BMW I3
On my Taycan the side view mirror lights on the ground at night, but no word about it in the Macan configurator. It is described in the Taycan configurator, so I guess we will not have light at night 🥵
Will double check that out the end of September at the dealership customer introduction day — and post back here.
Mike in CA
Mike
North Bay Area CA
To clarify my earlier post, there is a light in the side view mirror housing of the base Macan that I have as a loaner. However, I'm fairly certain the optional "Porsche" illumination is not visible unless you open the door. If you look at the description in the configurator, the Porsche version is described as an "Under Door" light and is actually in the door itself, so I don't think there is any way for the light to project unless the door is open. I suspect that the Porsche light is like the one in my wife's Audi e-tron which projects the 4 ring symbol onto the ground only when the door is opened. I wouldn't have paid for this option except that it was already included in a car we bought off the lot.
Bottom line, the "Porsche" symbol light is redundant to the other lighting and that's why I think it's more gimmick than functional and not worth $320. Just my $.02.
sarinotropeano
Sarino
New Jersey
2024 Macan 4 EV
On my Macan 4 the mirrors have lights that illuminate when the doors are unlocked. I did not opt for the upgrade so the puddle lights (the lights that are located in the door on the interior bottom) are plain. The upgrade would have the wording of the model.
I just got and put these puddle lights on that shows “PORSCHE” letters. The cost was about £40 for the 4 lights from AliExpress. Much cheaper than the Porsche's offering.
Someone had mentioned somewhere the car might need updated to power these lights (PIWIS), but that was not necessary. Just plug and play DIY job. I did it, easily done.
https://www.aliexpress.com/item/100...der_detail.order_detail_item.3.685ef19cF1Um3c
prime
awharton
Porsche Taycan GTS, Mercedes EQC400
@Awaz Which model from this seller did you buy that fits the Macan EV? M10316-letter?
