other's chiming in on this "descrepancy" will help get Porsche's attention - like any major corporation the more feedback the better - and we need volume to get this any attention - if you agree this is a problem - you're welcome to use my letter as a template to forward to your local dealer/service-manager - if you do not agree this is an issue, you don't need to send the letter
Good suggestion, which I took. I just sent the below to Porsche Customer Service (I also included my vin in the email sent).
Both the Porsche news website, and the Macan EV configurator indicate that Macans have 11 kW onboard chargers (the configurator stated that my car has an 11 kW charger). The charging behavior of my Macan 4 implies otherwise (the car never indicates greater than 9.3 kW when connected to my ChargePoint chargers at different sites, which are both configured to provide 10.5 kW (240v x 44 amps). The EVSE’s themselves also indicate a max of about 9.5 kW during charging sessions). Several forum reports I’ve seen agree with this observation (i.e. imply that the onboard charger is 9.6 kW +/-).
Could you please review and confirm the actual onboard charger capacity, and provide an explanation of why the capacity is different from promised if that is the case? In my situation, I specifically set up hardwired EVSE’s in anticipation of being able to charge my Macan at over 40 amps, and would not have done so if I had known that my Macan would not exceed 40 amps.
If the onboard charger is in fact 11 kW, how do we take advantage of that capacity?
this is a bit funny - but it's not…
literally for years the Taycan site in North American listed Taycan as a 9.6 kW onboard charger - but it actually shipped with an 11 kW charger - and Porsche never updated the website…
so now in 2024 the Macan lists the onboard charger as 11 kW, but actually can only charge at 9.6 kW…
Porsche's EV charging game is weak and they are just confused - I'll be interested to hear anything if they choose to address this issue…
the thread I started with Taycan in July of 2020…over 4 years ago - Porsche was confused by what they were actually shipping…
https://www.taycanforum.com/forum/t...-charger-48-amps-not-max-9-6-kw-40-amps.1793/
Wow. Very interesting thread, even though 4 years have passed (and I have never owned a Taycan or anything made by Tesla). I see there are other related threads on the Taycan forum also.
It appears Porsche is still confused! That's really not so funny, is it.
DuckMan
NH
9.3 kW here on a 48 amp setting Charge Point. Does all the scheduling correctly, but would like to see the car charge at the rate advertised.
whitex
WA, USA
pic below is my Macan charging from my PMCC unit provided w/2021 Cayenne TurboS eHybrid - note the amps is more than capacity - hmmmm…
PMCC is showing advertised capacity, it looks like the car is simply not respecting it, or the PMCC measurement has issues. Did the Macan show 40.7A as well? Did you try it with Tesla wall connector (see what Amps reported by the UI)? Maybe they forgot to account for the overhead used by the car and charger, and only throttle based on the output to the battery? Possibly that is why they lowered the 11KW to 9.6KW (next step down in firmware probably), because the car was overshooting too much?
Perhaps Porsche put the engineers who designed their EVSEs to now design the onboard EV chargers?
that was the Macan charging from the Cayenne's PMCC…I broke it out for testing to "see" what was going on.
whitex
WA, USA
Yea, but was the Macan in fact drawing 40.7A when only 40A was advertised? PMCC can talk to the car via PLC/ISO 15118 (not sure if Macan can do with with PMCC), so different protocol than SAE J1772, maybe they forgot to test it? Drawing 40.7A sustained on a 50A circuit would probably be an electrical code violation.
can not tell because voltage is not reported - PMCC showed 40.7 amps - no voltage information - and the Macan shows 9.3/9.4/9.5 fluctuating - with out the actual voltage at the moment we can't tell if the Macan is pulling 40.7
I just know my Taycan never pulled more than 39.7/39.8
whitex
WA, USA
Does the Tesla HPWC show you the current used? IIRC you can set it to 40A via the app. (my HPWC's are Gen2, so no app, but 80A).
Alternatively, do you have an EE friends with a meter who know how to measure current?
I just got off the phone with Porsche North American customer service and a Macan EV "expert". The expert told me that the maximum charge rate of _ANY_ EV in North America is 9.6 kW - when I asked them then why the Cayenne eHybrid, Taycan charge at 11 kW - they had no response. I also asked them if the maximum charge rate is 9.6 kw then why do they sell a 19.2 kW onboard charging option for the Taycan? They had no response. When I asked them why a 2022 Audi eTron SUV can charge at more than 9.6 kW they had no response…
I then also asked them if the maximum charge rate for _ALL_ of North America is 9.6 kW they why they sell the porsche Wall Charger with a maximum charge rate of 19.2 kW on a 100 amp breaker - they had no response…
they suggested I document the issue with my local service advisor - and they can "escalate" - I plan to bring my Macan to my local Porsche service advisor where I know they have a Porsche Wall Charger that can do 19.2 kW to test the 19.2 kW on-board charger option for Taycan's - we'll test the Macan on their 19.2 kW (100 amp breaker/ 80 amp charging capacity) and then escalate that we never see more than 9.6 kW and go from there…
{sigh} Porsche remains 100% f'ing clueless even 4 years after shipping the Taycan - they simply have no idea what to do in this space.
the "core" confusion that seems to keep coming up - is the different charging limits for _MOBILE_ EVSE's, the onboard charger, and regional limits - Prosche can not seem to keep the difference between the maximum rate their EVSE can provide (9.6 kW) and the maximum rate the onboard charge can accept straight -the "expert" also told me charging the car with a non-porsche charger is not supported - I then asked how I'm supposed to charger at Electrify America, ChargePoint, EVGo, Blink - and they had. no response.
Porsche is 100% f'ing clueless with regards to EV's - no wonder they want to go back to gas cars - the new world confuses them.
this by the way is related to my negative opinion of Porsche EVSE's - they have had numerous issues - but the biggest problem is that if you have _ANY_ problems with a Porsche EVSE (say for example it can't charge your BMW i3) - trying to work with Porsche to resolve _ANY_ issue with regards to charging, and/or one of their EVSE, you run into a brick wall of lack of understanding - you might as well be trying to explain orbital mechanics to my dog - they just have zero understanding of anything to do with EV charging, EVSE's or their role in this whole eco-system…
DuckMan
NH
You are the man for keeping this on the burner. Please let us know if you need additional signatures, letters, etc to support escalation. This ultimately may lead to a better vehicle. Also might be worth reaching out to Timo Resch if you have any contact info with a link to this thread.
please call or write and if possible have local service center document that you can not achieve an 11 kW charge rate as promised in the Macan's standard equipment specification…
to our European owners - can anyone in Europe document (potentially w/screen shot) that they can charge at 11 kW from a European L2 EVSE?
thanks,
rmwrip
Rick
Madison, WI USA
Will the BMW charger I am using for my 3 year old x5 hybrid work with the Porsche?
Thanks
Thanks
it should work - none of these chargers are vendor specific - at least they are not supposed to be - for North American they all conform to the J-1772 standard for charging an EV - if there was no standard you couldn't use public chargers…
I just got off the phone with Porsche North American customer service and a Macan EV "expert". The expert told me that the maximum charge rate of _ANY_ EV in North America is 9.6 kW....et al
You know what? That is flabbergasting. That level of ignorance from an "expert" is just beyond the pale as far as I'm concerned. I mean it's frightening. I am speechless. Porsche should be completely ashamed of this.
