Plug and Charge works after reset
krishmd
macan 4
An FYI for those with a similar situation
My plug and charge wasn’t working ( it was grayed out)
I went to the dealer and we did a full software reset.
After the reset it wasn’t immediately working, but after about 20 minutes we checked and it worked.
If you do the reset at home, wait some time and it should work.
Most of my car settings stayed active. I had to re do my Homelink and download my weather apps.
Jetced
Cedric
Bratislava
Macan EV turbo 09/24
also worked in my case. Bit annoying, but the reset was quickly done
andics
How do you do the reset from home?
krishmd
macan 4
It was in one of the settings pages. The service guy was in the car with me and he didn’t use anything special ( equipment or codes)
It could easily have been done from home , but I wouldn’t have known about the waiting, since it wasn’t operational immediately. I got the car washed and about 30 minutes later we tried and it was operational.
Minternico
Ambler, PA
Macan EV 4
Minternico
Ambler, PA
Macan EV 4
Had the same issues and went back dealer.., then when home had to reset garage door… but all good now… slow start for Porsche out of the gate on the Macan 4 !
dieterf
Dieter
2024 Porsche Macan Turbo EV
Be careful, if you reset at home you may lose your manual in your PCM. This is something that will need to be reinstalled at the dealer. It happened to me.
Fadz
Ferdinand
San Diego, CA
Same happened to my Macan 4. On day 1, Plug and Charge not working. Called the dealer sales rep and told me to call 1 800 Porsche which I did. While im on the phone with customer service rep, instructed me to do a factory reset. After about an hour wait for the software reboot, everything is working; able to install certificate/enable plug and charge.
bb1
Hi, same for me on my Macan Turbo, after 10 days without any automatic correction from the PCM, I found the trick here and it works perfectly. Thanks
henrus
Henry
Bay Area
Worked for me as well, except the clock is not correct and you can’t turn on auto sync
Spoke to my SA today about Macan EV and if they had any problems. He said they cannot make Plug and Charge work even with the Porsche rep. He said they have no solution. I did not try it on my test drive since lot cars have Guest accounts.
It would be helpful if someone could post a step by step with certificate install instructions.
M324
Martin
Germany
Porsche Macan electric 4S
This means that you are not able to set the correct time after the factory reset? If yes, then I guess I wouldn't do it.
henrus
Henry
Bay Area
You can set it manually. I waited a couple days to see if it would eventually set itself on its own, but I got tired of waiting.
Markan 4S
m
amsterdam
macan 4S
any idea where in the settings…? Would save me a trip to dealer
henrus
Henry
Bay Area
