Macan EV Charger Cover Flap Not Flush
JonoNZ
Jonathan
Auckland, New Zealand
Electric looks pretty good to me, glad I went that way now. Getting the manual flap replaced and colour matched will not be that much fun.
It probably takes 2 minutes. If this is a widespread part problem, as it seems to be, they'll just paint a bunch at the factory and distribute them as needed to be swapped out.
JonoNZ
Jonathan
The factory might have trouble matching the colour perfectly, just saying.
Shark29
MACAN 4 EV
Bonjour,
j'ai également eu ce petit problème.
Electric Macan EV Macan EV Charger Cover Flap Not Flush Tra
TurboSpain
Spain
Aha, that's the culprit of the range issues. Hundreds of hours of wind tunnel time wasted!
Seriously though, I just saw a Macan with a manual cover flap at the dealership and it was perfect. Must be a faulty batch.
Grumpy
W Sussex
Mercedes SLK Mercedes SL400. Abarth500e electric. . Porsche Macan 4 electric
Would. I be right in saying that the faulty flap is only on the RH ( passenger for you Americans ) side? If so it is definitely a manufacturing fault
raybey
Ray
Suffolk, UK
Macan EV 4S
Mine aren't great on both sides
nulled
The electric flaps aren’t perfectly flush with the body. It seems they don’t quite follow the natural curvature of the car’s design and appear slightly flatter. This is particularly noticeable when observing reflections, especially on darker-colored cars.
Electric Macan EV Macan EV Charger Cover Flap Not Flush Photos 2024-12-31 12.45.48
My caps are also both misaligned. Not damaged. Guessing it was a whole batch of the arm mechanism. Dealership is looking into it.
i wonder if the close height can be adjusted..
Panamera Frank may well be onto sometihing, that the arm itself might be the source of the problem on at least some.
Big Grack
Neil
Hampshire UK
Hi there
When I mentioned it to my dealership I was told “Porsche UK are aware of it”. Later I was told ”there might be a recall”. Should I push for more information?
Ranj
Ranj
Birmingham
Macan 4 EV, Macan 3.0 SD, M4
Hi there
Yes, definitely as Porsche Solihull fobbed me off and said they could not do anything and other Macan’s with manual flaps are similar. I have emailed Porsche UK
