Wheel / tire size and winter performance?
xrtdr
J.
OH USA
2024 Macan 4
My Macan 4 (leased Dec 31) came with 22 inch tires and all season Continental. The sales team assured me they would be fine in light winter conditions.
I found over the last week that they slide bad on light slush and snow.
What is the thinking on wheel size and winter safety? Do I have any recourse to get Porsche to help change the wheels or provide winter rims and tires?
Sideline
Unfortunately, too many assume that all-season tires are suitable in "light" winter conditions but my experience (45 years driving in Ontario) is that all-season compound will loose grip when temperatures are below freezing, even when roads are dry let alone when there's slush and snow. That's where winter tires come in.
With respect to wheel size for winters, the diameter is less important than the tire width (although they are correlated as width generally increases with diameter). The smaller diameter (taller tire wall) will provide a more compliant/softer ride and possibly some benefits in grip or ability to plow through deeper snow. Porsche's winter packages are available in 20, 21 and 22 inch wheel sizes (at least here in Canada). The width of 20s are 235 front and 285 rears, the 21s 255/285 and the 22s 255/295. So the 20s will likely be your best choice for ice/snow performance but if you like the look of the 22s on your car, the 20s may look a bit anemic by comparison.
My Turbo was ordered with 22 Macan Sport wheels with all-seasons but with a mid-December delivery, I had my dealer install 21 Turbo winters with Michelin Pilot Alpin 5 SUV tires (I do the seasonal swap myself so I just store the "summers" at home). I tend to hold on to my cars (I've never owned one for less than 9 years) and I plan to do the same with my Turbo so it was easy to justify a winter-specific wheel set. My last daily driver was a 981 Cayman S which I drove through 9 winter seasons ?.
Since you're leasing, I'm guessing you want to avoid the expense and hassle of having two different wheel sets. I suppose you could save some money by swapping winter tires on to your 22s. With respect to recourse to your Porsche dealer, I suspect you have none. Maybe they'll offer you a discount on winter tires/wheelsets but I doubt they'll do much more.
xrtdr
J.
OH USA
2024 Macan 4
Thanks I appreciate the thoughtful answer
Yeah, wide tires and slush do not play well as the tires ride up on the slush. Wide tires with sticky low temperature rubber on ice play better than narrow as there is more chance of catching a bit of traction. Winter specific tires wear much faster on summer highways. All Seasons compromise winter traction for tread wear and noise/smoothness. Summer tires and winter are a dangerous combination. The Macan has very wide tires.
Pick the compromise that suits you.
My compromise is a Pickup with narrow tires for nasty weather, and a car with "performance" all seasons otherwise (can handle cold weather). The car just sits in the garage during nasty weather or when forecast which is usually the entire month of February.
Wheel size plays a role but the difference from the Macans 22 to 20 isn't going to make a huge difference.
What will make a difference is the tire itself. All Season tires are awful in winter conditions and awful in summer conditions. The joke is they're really "no season" tires.
You can check any of hundreds of tests and all season tires drastically underperform dedicated winter tires in winter and summer tires in summer.
Porsche is also known to use pretty terrible OEM all season tires. I'd at least want something like the Cross Climate, which still performs worse in winter than the cheapest winter tire but significantly better than most All Seasons.
I've never understood paying six figures for a car and then scoffing at swapping tires twice a year, which has more impact on performance than any option you can spec.
Wobbler
Kev
Porsche Macan 4S EV
My last car was an Alfa Romeo Giulia Quadrifoglio - 500bhp, rear wheel drive. On winter tyres, I routinely cruised past 4WD’s stuck on the 1:9 hill at the bottom of my lane.
It’s about tyres, not wheels
Exactly.
Knowing that, when two more models were announced, I cancelled my Macan 4, and went for base RWD, as I have had RWD BMWs many times. Always liked RWD dynamics. I think rear-wheel drive are more fun in general, particularly if you get a chance to really play with them and have the talent to go a bit sideways.
Also, the base Macan will have the best turn as there is no electric motor assembly upfront, the front axle will weigh less and reduce some inherent friction from the steering.
Added more options in the base model and the price actually got a bit more than the Macan 4.
I actually test drove Macan 4 and found no noticeable difference in this and the base version. Acceleration is pretty good in both. Besides, I much prefer it has the most range :)
i've been using pirellil all seasons on my cars for a long time now, and I have no complaints. I do agree about the info given in regards to the width and going over snow/water as opposed to through it....
next best thing you can do is have dedicated winter wheels/tires...
Dragon Tourniquet
Nevada
I think the bigger problem is variable climate. Some areas can go from subfreezing night temps to 80+ day temps in a week. If you then switch you can get caught because sometimes it will then drop back to subfreezing after a week again as a last gasp of winter. The reverse can also happen. More likely when you live away from a large body of water (since those are better at regulating temperature than land).
Extreme example: when I was in college (decades ago) in Tucson, a week before Easter the highs were in the high 80s. By Easter the temps had dropped enough that it actually snowed (lightly) around 11am. Then the following weekend was the highs were back up to high 80s. Winters or Summers over that 2 week period would have been bad for it.
I went from 21" with summer tires to 20" with winter tires and I have no problems here on the Alps (I always used winter tires and never "all seasons" tires for the reasons many have already pointed out). And for critic situation I have snow chains. I found out that it's better to be prepared than having the car smashed on the side wall (or worse here at the bottom of the ravine....)
Informative video
Such horrible roads. No wonder folks are complaining about bigger wheels on roads like that.
