Macan EV Charger Cover Flap Not Flush
Well, if there is TI (Technical Information) on how to adjust the misaligned charger flap, then ideally if the dealerships order new ones then Porsche should refuse and direct them to that TI ?
You would think that would happen. The TI is new so maybe from now on
sm06
Sameer
macan 4 EV
Man...these guys need to do their jobs. It took my guys almost no time to figure this out. The internal document (which they did not show me but explained in detail) is called a TI (Technical Information). They should call the Victoria BC service department if they cannot find it but if you have to tell them that ....well that is messed up big time....just saying...lol.
I can only imagine they would have done their due diligence before ordering new parts. Porsche Warranty services wouldn't have approved the parts and labour for my particular vehicle if the fix was simple in this situation.
themacnut
Jeff
Boise, Idaho
Cayenne S, 911 Targa 4S
I think both scenarios may be valid. Some can be adjusted, some are out of spec and may require new doors.
I would guess if some doors are being ordered and sent to be replaced, they had a bad batch of doors from their sub tier supplier.
Porsche doesn’t announce these things. They quietly fix them.
LinuxLars
Larry
Fort Worth, TX
My Macan EV Manually operated charging flaps on both sides do not sit flush.
I went to Porsche dealership Solihull UK and they said it was in tolerance.
To me it isn’t within tolerance given it’s a Porsche.
Anyone else noticed this ?
Agreed. I took delivery of my 2024 Macan EV in September after ordering it in February, as was told it was the first delivery in Fort Worth, so mine was shipped very early. I mentioned it to the sales and service reps, they said they all look like that. Hoping it's a slight imperfection that gets fixed in the new vehicles. The car is really terrific, and I love it.
LinuxLars
Larry
Fort Worth, TX
Same. Both of our manual charging covers aren't flush with the body, and all of them I've seen have the same issue. FWIW the dealer says this is normal.
Fortunately there is enough evidence on this forum to refute any notion of this being normal and that there is a service fix in place
M324
Martin
Germany
Porsche Macan electric 4S
My dealer said there is no technical information available regarding this topic... I've asked him to look for it last week.
Dek
Derrick
Annitsford
Both my charging doors were fixed by Porsche Newcastle the car was sent to body shop and re aligned don’t know how they did it but they are now as you would expect.
JesmondGus
Freshstart11!
United Kingdom
Snap, Macan was in dealership (Newcastle, UK) for a separate issue (boot lock failed!) and the charge ports came back flush. Not that the dealership mentioned this or detailed it on the work report.
pearson1995
England
Ford Fiesta
I ordered my turbo recently, yet to collect. We discussed the electric charging cover and I said I don’t think it’s needed, he said its convenient but also, it sits flusher than the manual ones. Something I think should be drawn to anyone’s attention looking to buy. I don’t think this is an official comment, but good to know.
Hut49
Horsham
Macan EV Turbo, Carrera S Cabrio
My dealer knew about these issues. It’s a small adjustment on the door. Said it happens commonly on various models.
Same with mine. I indicated that I was not happy about the fit of both flaps during handover. The car was taken back into the service area and reappeared 20 mins later with a 95% improvement after the 3 locating points on each flap were adjusted. It's not perfect, and I agree that it should be on a ÂŁ110k car. But it can be adjusted - that's the takeaway from my experience.
So my driver side flaps were always perfect and the passenger side was off. I took it in about a month ago and it wasn't resolved and was told that a new part was to be ordered in for me.
This morning i went to check my passenger port and it was magically 95% flush. LOL
I will have to take some close up pics to confirm maybe it was just too early in the morning for me.
When new I notice either manual flap a little off from time to time. A little pressure on the high spot put it back into place Now that there is a couple thousand miles on it I rarely notice them being off. It is as if a gasket isn't seating right and needs a bit of time to break in... Mine has nearly the right shape, however.
