- First Name
- Inez
- Nov 27, 2024
- Canada
- Macan 4
When I first got my Macan 4 and I started charging it using the mobile charger that came with it, the lights would flash green when I plugged it in. Then a month or two ago, I woke up and all the lights were lit solid red. I found it odd, and even after I removed charging port from the car , it remained lit solid red. I couldn’t reset it by pressing the reset button on the bottom either. I had to unplug it in order for it to reset. Now, it hasn’t done that again, however every time I plug the charger to the car, all the lights now flashes red. then the 50% or 100% lights up green, but the power light is now yellow. Now I’m not certain if it used to be white, green or yellow, but I feel like it wasn’t yellow before.
I’m wondering if your macan 4’s mobile charger does the same thing as mine. My local Porsche centre told me there is nothing wrong with the charger or the PCM control unit. And they even told me that the lights flashing red is a communication handshake between charger and the vehicle and that it is normal. But I’m skeptical, and I am not sure if I can trust what they’re telling me.
Upon reading the owner’s manual, any kind of red lights typically indicates a possible fault.
So what should I do? Charger is currently charging. But the red lights worries me.
See attached video.
See attached video.
