- First Name
- Tim
- Jun 13, 2025
- Colorado
- 2021 Ford Mustang Mach-E FE, 2025 Porche Macan Electric
I think there may be a problem with my air flow/vents. They sound a little like a leaf blower. Even when I dial the fan manually down to just "1", I hear an unusually loud "whoosh" of air sound coming from inside the dash area, as though there's a shutter or diverter in the vents that's trying to close but isn't quite sealing. Kind of like the sound you get when you leave a window open just a crack and you hear the whoosh of air squeezing through.
It only goes away when I dial the fan to "0". Even just "1" makes a rather loud whoosh, far louder than I'd expect. Almost all-or-nothing, as it doesn't seem to get much louder at high fan speeds. The airflow coming out of the vents seems correct though (changes as I'd expect with fan speeds), but the whoosh sound stays pretty consistently loud unless I turn the fan completely off.
It's similar with the rear vents too. They're very loud. I always turn them off when I get in the car because it's quite distracting. And they seem to come back on automatically nearly every time I start the car back up. (And yes, I've checked to make sure the vent flow slats are all open.)
Does it sound that way to everyone else too? That just doesn't seem normal. I can never hear a whoosh like that in any of my other cars unless I turn the fan way up.
