Unable to close boot
Cozzer
Col
Macan Electric
Has anyone had a problem where the button won't close.
I don't have comfort access, but when I press the close button, it attempts to close, moves a bit and then beeps.
The only way I could get it to close is to pull the boot down half way and press the button again.
I didnt have any issues before the update either
TiLaSoul
Macan EV 4S
I think there's a proximity sensor so if you don't move away from the boot, it will beep at you and not close.
Try pushing the button and moving away.
Sounds like it is detecting an obstruction of some kind.
Don't stand too close once you've pressed close.
May need to relearn the position.
Lock car and leave for a while.
Cozzer
Col
Macan Electric
I tried resetting the boot opening height by holding the button, but that didn't resolve it. It's happened twice this week. I thought it detects obstructions from resistance on the struts.
Cozzer
Col
Macan Electric
It's gotten ev worse now. Everytime I open the boot it won't close at all. Keeps giving a beep as though there is a obstruction. Opening from the drivers seat, same thing, can't close it again from inside the car.
Anyone know how to disconnect the 12v battery and let it reset and recalibrate? .
Last time the AA guy undone the bolt but the car was still powered, he had to do one more thing before it went off. I wish I asked at the time.
SeaMonkey80
Maneesh
SF Bay Area
2025 Macan 4S Electric, 2024 Rivian R1S
I had this problem too. The solve was to set the boot lid open height at the mid way point, and then open and close it a few times (it should only open up to that midway point). Then, I could push the boot lid up higher, set it and it would close. See if that helps.
Cozzer
Col
Macan Electric
Thank you so much, that worked. I did it at the half way mark, set that height. And that managed to close. Then I pushed it to the height I wanted and set it again and it works now.
I think because I adjusted it by an inch or two earlier in the week, it could be confused the position I moved it to.
My old X5, you set the height from the menu instead.
SeaMonkey80
Maneesh
SF Bay Area
yeah, there is clearly some kind of programming glitch. I'm glad it worked!
Also proximity and if key is present. So press the button to close and step away quickly to see if that works if not then dealership.
Cozzer
Col
Macan Electric
I tried standing at the side of the car and it didn't like it.
I think I caused the problem by adjusting it by 2 inches and trying to set it again.
Setting it half way and then doing it to the proper height seems to have resolved it in the end.
Was getting worried as I used to be able to open and close from the driver's seat previously and that had stopped working.
aks
Tony
Hertfordshire, UK
BMW F90 M5, BMW F48 X1
My BMW does this *if* the key is actually in the boot, i.e. in a jacket. Maybe the Macan sensor for the key is too sensitive?
anders1
Anders
Sweden
Macan EV Turbo 2025
I had this problem on my Turbo. Needed a trip to our dealer. Apparently the sensor that tells the system what position the lid is in had lost its calibration. I couldn“t fix it through the above mentioned steps by holding down the close button. They used the service software to reset it and since then it works fine.
Cozzer
Col
Macan Electric
I fixed it by setting the open height to very low. Closed it and then open and manually push it all the way back up and hold the button. I think I broke the calibration by setting it an inch lower than it was.
I had a similar problem. The boot would close but not the final ā€˜soft close’. I could only drive with the warning buzzer. It was Saturday, so I took it to the dealers not expecting anyone available but yet again Colchester provided an excellent service. The technician did all the checks I had done - check nothing fouling and reset the height and couldn’t sort it. Took it to the workshop and did a reset and it has been fine since.
As it appeared to be a software problem and not mechanical plus anders1 had the same problem and resolution - I do wonder if the update caused the software to get a little lost. The guy said he hadn’t come across the problem before.
Reactions: aks
Same issue with the boot not fully closing happened today. I manually closed it and it shut and the warning was turned off. It’s going in for the battery balance issue in mid April and they’ll hopefully fully resolve the boot soft close’.
