Any essential specs to order?
Has anyone been able to verify if Surround View 360 is included with the 4S. I have not gotten an answer from my SA but thought I would ask again if anyone has any new information. Thanks I do not lock until the end of Sept so I have some time to figure it out.
Click the standard spec sheet button on the configurator to see what you get.
Next, If 360 not listed as an option in the configurator then its standard. NA region typically gets packs - premium and tech as options one of which will contain the 360 option.
wmras
Bill
Oregon
Can't have noise insulating glass if you tick the wiper option (unless this is a bug in the configurator).
Not a bug. The sound and thermal glass is actually thinner, lighter, and stronger than standard glass - the multiple layers of plastic in the middle make it so. The wiper mounting probably needs the thicker standard glass, but that is just conjecture.
Mike in CA
Mike
North Bay Area CA
2021 Taycan 4S, 2019 e-Tron, GMC 2500HD Duramax
AFAIK there is a kind of foil inside the front window (e.g. our 12/23 Cayenne has this feature) and no more "wires".
Just my 0,,02 €: With preheating in EVs i can not see the sense...
No heating element visible in ICE Macan - different tech to Ford / Volvo - rather there is a film in the glass which heats. My wife has it on her car.
Thanks for the clarification on the wires. The other issue that I've read about is that the heated windscreen can degrade the performance of a radar detector, which seems to make sense if there is a foil material present in the glass. Apparently, there is a small opening near the mirror though which a detector can "see", but it is difficult to position a detector so that it works well. Or so I've read; no personal experience with this.
taycanstuff
taycanstuff
Ice Grey 4S
Another essential is side airbags in rears - ÂŁ315 should really be standard on all models but would hate to think something happened didn't tick the box.
MFitz
Michigan
Macan 4S PS88FTV9
My SA finally got the answer on the Surround. Here is his answer. Surround View with Active Parking Support is standard on the 4S and Turbo.
Hopefully that settles it.
So it may do that as it looks like the noise insulating glass (which we don't have). Not noticed any interference issues at all but aware that insulated glass can be problematic for toll readers and cellular connections.
Odd - I checked the NA configurator (and standard spec sheet) yesterday and the standard spec doesn't include this on either car. You must option the Premium Pack to get this and other tech. Personally, I would check again and suspect the Premium Pack is built into your offer to make it appear "standard".
In the US, the Premium package includes:
Turbo
- Ventilated Seats (Front)
- Heated Seats (Rear)
- Advanced 4-Zone Climate Control
4S / 4
- Power Seats (14-way) with Comfort Memory
- BOSE® Surround Sound System
- LED-Matrix Design Headlights
Surround View with Active Parking Support is an option that can be selected only on the 4, it isn’t available nor listed as standard for the 4S and Turbo.
But it has been confirmed by several reps it is standard on the Turbo even though not showing on the config (and seemingly same on 4S).
Could you please confirm which configurator you were looking at?
Turbo
4S / 4
I went specifically to Porsche North America (not Canada) and went through the process of configuring. Pretty clear to me that what I've said above is correct - part of Premium at additional cost. It could be semantics in that certain packs are always included for your region and built into the pricing structure to appear as if standard.
We don't get 'packages' in UK as a rule and so each item has to be selected if not standard. US market has always had packages but I assume optional and less granular.
MFitz
Michigan
Macan 4S PS88FTV9
I agree it is odd and that is why I had my SA pursue an answer. Now he could be wrong. He took a week to get the answer and said his boss spoke to someone above him in Porsche corporate and he felt that was the answer. Now of course it all feels up in the air. I will continue to work on the answer. Thanks for the input.
Not calling you liar, simply unable to see what you’re referring to.
Could you pense confirm the URL?
I’m not seeing a configurator for NA, only country specific ones like https://configurator.porsche.com/en-US/model/XABFD1/ for the US.
The US one does not reflect your point - and I’m sure the US is wrong,
So your build has the Premium Pack selected (I just checked) - $3,910.
It can be deselected which actually will increase your price by $760 if you add the options individually (don't worry - I haven't altered anything).
Here is the link to your standard specification before any options / packages are added - https://configurator.porsche.com/en...7.VC2.VF1.VL0.VR0.VT9.VW6.Z1C&variants=APM_G1
Electric Macan EV Any essential specs to order? Snag_69d7dc0
Electric Macan EV Any essential specs to order? Snag_69da4a1
See below 'YES'
I know I’ve not had coffee yet…and really not trying to be difficult here. But where on the config do you see “surround view” as being part (or not) of the Premium package or a standard option?
in the USA configurators - and Macan (base) and Macan 4 - surround view is:
  • not listed in standard equipment
  • is listed as a $1090 option
Electric Macan EV Any essential specs to order? IMG_2300
it is _NOT_ listed in Standard equipment _OR_ as an option for the Macan 4S or Turbo - but I'm betting it's standard equipment given it's lack of presence in the option list - but confirm with dealer - there is no mention of it in Premium Package description for either the 4S or the Turbo.
USA configurator as of date/time of this posting - YMMV
