- First Name
- Adrian
- Jan 11, 2021
- Aberdeen, Scotland
- 992.2, ex.Taycan GTS ST owner, Macan T (EV upgrade a tempter!)
Map updates for the PCM will include this stuff and will be OTA - expect these regularly and each are welcomed as the also carrying new EVSE location updates as well.I think I‘ve understood the point.
Apparently, the actual fix is not a firmware fix, it’s just a new version of the data map which seems able to be installed OTA. My guess is that there were a problem with units / mph / kph in the data, or lack of unit/values.
This is my conclusion thanks to Audi Q6 forums.
Is there a way to know the data map version in the PCM (there is in the Q6 MMI)?
