InnoDrive, Adaptive Cruise Control, Active Lane Keeping and Lane Keep Assist
Are you ordering your car with PID/ALK?
  • Total voters
    55
I have been a little confused about all of the above, what they do and don't do. After some research, stumbled on Jeremy Lawley's profile on Vimeo - seemingly an official Porsche channel called Academy Garage for their partners.
2 videos were particularly of interest:
Electric Macan EV InnoDrive, Adaptive Cruise Control, Active Lane Keeping and Lane Keep Assist 20
Episode 20: Innodrive w/Adaptive Cruise Control in a Taycan (MY23)
Electric Macan EV InnoDrive, Adaptive Cruise Control, Active Lane Keeping and Lane Keep Assist 21
Episode 21: Active Lane Keeping vs. Lane Keep Assist in a Taycan (MY23)
ALK is the one that interests me the most, I feel that with ACC I would be mostly covered.
Here in the US, ACC and LKA are standard features whereas Innodrive (PID)/ALK are optional ($960 for the bundle).
There doesn't seem to be another way to get PID/ALK unless spec'd when the car is ordered.
That was possible through Functions on Demand (FOD) on the Taycan, one could subscribe to PID and/or ALK individually on a monthly basis.
FOD is going away on the Taycan and it therefore seems unlikely FOD will exist on the Macan.
In the end, I do think I'll keep InnoDrive in my config - mostly for ALK. And who knows, maybe PID will be handy during the occasional roadtrip!
What about you?
ironcitijc
JC
NH
Macan 4S, Rivian R1T
Thanks for posting this. The video is helpful. I also spec'd mine out with it.
ThomasDK
Thomas
Denmark
BMW I3
If I understand it correct you need to Order innodrive to get active lane keeping. The car drives itself on bigger road with not to sharp curves. Stays in center of lane. Otherwise you only get Lane keep assist, and that is a joke. Driving from lane to lane, and keep telling you to take over.
I have innodrive in my Taycan, and it works well
That's my understanding as well, PID and ALK are a combo: you cannot get one without the other on the Macan. Thanks for the feedback on InnoDrive!
I dislike innodrive - but option it so that I can have it if I want it
I own 3 "innodrive" Porsches - 2020 Taycan, 2021 Cayenne, 2022 911 - on all 3 I have innodrive disabled and only enable ACC and ALK
my main complaints with innodrive are:
  • it aggressively matches speeds limits (up or down) - so it effectively brake checks who ever is following you if innodrive "feels" there is a reduction in speed limit (real or hallucinated *) - when using innodrive I have almost been rear ended by other cars (not technically innodrive's fault) - and given that this can happen for "fake/imagined" speed limit changers I personally have decided it's unsafe to have it enabled
  • it anticipates upcoming curves and adjust speed to match corning - it's quite conservative with it's cornering speeds and I was always "overriding" it with the accelerator pedal - so in the end I simply disabled it because of problem #1
  • there are other lesser problems, but the two above make it useless for me personally
I option it on all my Porsches for the following reasons:
  • FOMO
  • some small hope for future updates making it better? (less than 1% chance in my opinion)
  • guaranteed ACC/ALK support/sensors - car will have best sensors/cameras and other electronics required for innodrive
  • but mostly FOMO
but as noted - I have Innodrive "disabled" on all 3 of my Porsche's - but ACC and ALK are functional and useful - I occasionally turn innodrive back on to see if I was wrong, but normally that last less than a day as I once again almost get rear-ended due to innodrive slowing down for an imaginary speed limit zone change…
* - innodrive's accuracy with regards to speed limits based on current location lacks global accuracy - I've been tooling along at 65 mph in a 65 mph zone, and for _NO REASON_ it has just slowed down (aggressively) to like 45 mph - and then back to 65 mph - there is no rhyme or reason for this slow down other than inaccuracy in it's data maps or vision recognition - I simply can't have an automated system slamming on the brakes for a hallucinated speed limit zone change - it happen, it happens frequently, and it's dangerous given how aggressively the vehicle decelerates often times surprising driver's follow me too closely - it's disabled for my safety.
Crick
Crick
Palo Alto, CA
2018 Volt, 2009 BMW X5D, 2021 Taycan Turbo S
Same.
ThomasDK
Thomas
Denmark
BMW I3
You can turn the “follow sped limit of” when on innodrive. The left cluster will then say, transfer the speed limit?
Be cause you are right, the regulation loop PID-regulation is shit. Braking/acceleration in a jerking manner every time the speed limit changes. Much better to use after I disabled the automatic speed limit transfer
Crick
Crick
Palo Alto, CA
I'll have to give that a try. I like to be reminded of speed changes when approaching unfamiliar towns - cops are cops.
I have seen two folks on the Taycan forum who had previous Taycans who recently posted their new 2025 Taycans have improved InnoDrive. I think we can therefore expect as Kyle/OutOfSpec stated, that our Macan’s will have even better than the 2025 T’s due to its improved software.
wmras
Oregon
  • it anticipates upcoming curves and adjust speed to match corning - it's quite conservative with its cornering speeds and I was always "overriding" it with the accelerator pedal - so in the end I simply disabled it because of problem #1
Dave,
I use Inno Drive for braking a lot, ALK, not so much (wife immediately asks what's wrong with the car when using ALK). Braking for curves, blind hills, or intersections changes a lot, depending on drive mode selected, none are likely to scare you, but they might scare passengers in SPORT PLUS. Three years ago, I led my first Porsche club drive with our 2020 Taycan TS on very tight curves and hills in NORMAL mode and used Inno Drive to set the pace - three cars left the group at the first rest stop because of the slow pace! I have since learned the ACC can be set to 85 mph in SPORT PLUS and the Taycan will be amazing at braking properly - feels like a Porsche instructor is showing you how to trail brake.
When following others in a club outing, especially down a mountain, turning Auto Regeneration on does a great job of following the car in front of you, but a little close for rock-chip protection. I love Auto regeneration - it is the smoothest possible ride you can give your passengers - it coasts gracefully when you let up on the throttle and slows when traffic is in front you. My INDIVIDUAL mode is set to SPORT, LOW, Auto Regeneration ON, Sport Sound ON.
Active Lane Keeping is not graceful and gets worse if you have the ACC set to 2 or three seconds. It is tolerable for me if you set ACC to 4 or 5 seconds (but still not smooth).
As a side note, Adaptive Cruise Control in our Taycan can be set to 120 mph - all our other Porsche cars stop at 100 mph.
Interestingly ACC and Lane Keep are... STANDARD!!!!! for MY25 in US. It should have ALWAYS been the case and I'm shocked Porsche actually did it. I'm assuming some sort of regulation forced their hand.
taycanstuff
Ice Grey 4S
Hi All,
With all these connectivity issues we are having in the UK, can anyone confirm if you have Porsche Innodrive, we should be seeing this same menu with the option to select Porsche Innodrive.
I have Innodrive specced and I don't get this option on my dash? ?
Nothing about this option in the manual either:https://manual.porsche.com/#/wpi/XA..._GB/topic/id/2e4b43043c81675f8d24c0b306b78b13
yeah, i was just thinking the same...but i figured it was because the image is from a Taycan
Sideline
Hi All,
No, you won't see Innodrive anywhere in the menus. If you see Adaptive Cruise Control with Active Lane Keep, then you have Innodrive.
