For those of you with Rear Wheel steering... happy with it?
Rear wheel steering worth it?
  • Total voters
  • Poll closed .
are you happy with your choice?
I've seen mixed thoughts on it from the "journalist" and youtube /TT reviewers... But i wanted to get a round of the actual owners who have and use the option.
do you like?
Would you option it again?
Daniel
Europe
Sold:Taycan 4, Now Macan 4
After a Taycan CT without RWS, wheelbase 2.904 m, dim 4.974 x 1.967, not very easy to enter my garage, I have a Macan 4, with RWS, wheelbase 2.893 m, dim 4.784 x 1.938
The Macan is very lively in the curves, but to enter my garage, very frankly I am very disappointed, no notable improvement.
I even wondered if the option (that I paid for) had not been forgotten :crying:
I'm waiting the opinion of this forum ...
oh wow... maybe take it to an empty space, point your mirrors downward and take a look at the wheels while making a turn...?
5 degrees isn't much...but i saw a mercedes take a corner in front of me once, and it was SUPER noticeable that the car had rear steering!!
EdInSanDiego
San Diego
While parked but with the car on, open the door and turn the steering wheel all the way. You should be able to see the rear wheels turning (up to +/- 5 degrees). It reduces turn radius by about 10% so not huge, but something.
nulled
Very happy with it! Taking tight corners with much ease. According to the web the Model 3 and Macan with rear steering has the same turning circle even tho the size is significantly larger. I could also feel more stability when accelerating and overtaking. Also mountain roads are a lot more fun.
Throb
NL & UK
The Taycan is even less. I have it on my GTS, and it's not really visible to the eye, but as a driver you can definitely feel it.
I've driven a Macan Turbo demo car with it, and it's much more noticeable, both to the driver and anybody observing from the outside.
Some MB cars, I believe, turn up to 10 degrees.
I'm not sure that would work. I think I read somewhere the car has to be moving for the RAS to function.
Either way, you could just drive slowly forward, turn, and then look in the mirrors, or even just feel it as a driver. The Macan's RAS is easily detected from the driver's seat.
In answer to the original question...I have specced it on my forthcoming Macan Turbo, and I wouldn't even consider the Turbo without it.
There was a video posted on here a few months ago which clearly showed the RAS in action. It was a convoy of Macans entering a parking area or something, filmed from the street.
gianteli
Ireland
I think it's the best feature upgrade from my non 4ws Taycan. I find the turning circle to be much tighter, and navigating around a tight european city is far, far easier.
macanchan
Allan
I'm a fan of the RWS for right hand turns through intersections and U-turns. I would hate to make a 3 point turn with the dash controlled PRND shifting. When I first got the car, It would shift into neutral because I didn't fully click into reverse or drive. half click goes into neutral. someone else mentioned the RWS can be dangerous for parallel parking and scratching wheels. I declined the wheel protection package so i'm extra careful with the RWS and parking.
oxum
Estonia
There's a post I pass by when parking under the carport. I used to clear it the same way for 3 years with the Taycan with RWS, always the same motion, passing by it 5cm away.
First time turning into that spot with the Macan with RWS I almost hit the post, because it turned that more quickly/aggressively than the Taycan.
It takes some getting used to, especially minding the curbs when leaving a roadside parking spot. But overall there's no denying the turning circle is reduced by a lot for me.
ohh gotta find that !
Did they all have it? ?
Damn the macan looks good with 22's
SupremeHustle
Minneapolis
2025 Aston Martin Vantage
"Overtaking." Okay, let's settle down, Max Verstappen. ;)
RunningOnSolar
Scott
Ohio
Macan 4, Subaru Solterra
Both my previous car and our other EV have a comparable turning circle to the Macan with the RWS option specified. So what you’re used to matters hugely in this decision. It certainly has made a difference when parking so I have no regrets with my decision to include it.
