- Apr 30, 2022
- NL & UK
- Audi R8 V10, Macan Turbo, BMW i5, MB C-Class
You're talking about two completely different things, and also misunderstanding what was meant by "battery depletion". You've also missed the reference to "from new".can't both be true?
if he's sayign regen doesn't start till after X number of KhW are used...those KwH would still equate to miles. If a battery needs to be depleted first, doesn't it equal out to be about the same 300+ miles / 1 full battery state ?
The Macan and Taycan (and I assume other electric vehicles) don't activate regen for the initial 300 or so miles FROM NEW. This is to bed the brakes in, which is something ALL vehicles need when new. If regen was available, the friction brakes would be used a lot less, and therefore impede the bedding in process. Once this period has passed, the regen will then be activated. This process is entirely automatic and handled by the car. macanchan was suggesting that this process was a myth, but has since accepted it is a thing.
The other system behaviour where regen will not happen is when the battery is at 100% charge. It makes sense because how can you charge a battery which is full? After a few miles, when the battery charge drops, regen will then become active again.
