Realized, I was seeing to that it shows a little Regen if u have Regen on and are coasting...that is what I saw. When brake applied it does not change the amount of Regen I do guess I am still in the break in period
Try a hard deceleration pressing hard your brake pedal. You should see the green indicator going backwards from noon to about 10 0'clock .
...at last...And I thought noone would do this kind of test.
Long story short:
@100Km/h distance 21,4Km 17,6Kwh/100Km.
@120Km/h distance 22,3Km 22,2Kwh/100Km.
@140Km/h distance 23Km 26,6Kwh/100Km.
@160Km/h distance 21Km 36,1Kwh/100Km.
OAT 15° Degrees.On 21' wheels.
Long story short:
What was more impressive was that the charging went from 10-80% in only 22 minutes
Jealous of your consumption number Diego
Yes, impressive figures.
@Diego clocks up the mileage by just sitting in the car pretending to drive ?
Would really love some more trip reports from strictly highway driving. Preferably at least 30 mi/50 km without stopping on mostly flat ground with temperature and average + high speed listed.
Daniel
Europe
Sold:Taycan 4, Now Macan 4
Better ..... with good weather conditions 17° C Gap (730 m asl) to Versailles (120 m asl)(FR) , mainly highway
Electric Macan EV Real consumption / range / efficiency thread … post your Macan EV performance 📊 Gap Versailles FR
Better ..... with good weather conditions Gap to Versailles (FR)
I hope this is not the Turbo being so much worse … on paper the difference is way less, I drive normal with similar average speeds … and on 20 inch wheels …
At average speed of around 120 km/h on the highway I average at around 24kwh/100km at 12C so I guess 21 - 22kwh/100km at 25C
(The lower average was a turnaround and getting to and from highway that is really negligible most of it was driven at 120km/h)
Electric Macan EV Real consumption / range / efficiency thread … post your Macan EV performance 📊 1730576310867-
Yeah, those really aren't great numbers. It's interesting to see how much yours differ from others. And you say you're on the 20" wheels?
Sure, you'll lose some range at 12c and some range at 120 km/h but I'd still expect a bit better than 24 kWh/100km. Sub 400 km range on the highway in fall weather is a bummer.
Indeed my iX is way higher in range … I do not understand the figures of the Macan 4’s they are OK.
