  • Total voters
    45
whitex
WA, USA
On the subject of whether the Macan shows gross power flow: I just tried the Macan on my 240 volt 16 amp EVSE. The Macan showed 3.8 kW (which would correspond to the maximum gross the EVSE should be able to supply. The EVSE itself displayed: 237 volts, 15.7 amps, 3.7 kW. Aside from the minor discrepancy, it is interesting that my car shows the full rated power on the 16 amp EVSE, but maxes out at showing 9.4 kW when supplied by my ChargePoint at 40, 44 and 48 amps. (Even at 40 amps, it should really be 9.6 if it is taking the full draw.)
Edit: on thinking about this a bit more: in the case of the 16 amp EVSE, the EVSE would be telling the Macan, "my max is 16 amps." If the Porsche power meter is anything like its speedometer, then maybe the Germans actually built in a little wiggle room there, so it doesn't over draw? (Meaning, it takes 3.7 kW when the limit is 3.8 by being a touch over optimistic--so the car says 3.8 when it's really taking 3.7?) Then again, that would be inconsistent with the conversations about the car taking 40.7 amps when it should be taking 40.
The 40.7A was shown on Dave's Porsche EVSE, so it was end-to-end Porsche environment, meaning we're dealing with some sort of German precision example (either measuring or actually consuming). Perhaps they need some Swiss watchmakers on their team to improve their precision? ;)
Paul
Porsche Macan S 2019, Macan 4 EV 4WS
I voted #2. Macan 4 with a span drive on a 60A circuit - Colorado
Kal-El
2025 Macan 4S
Just brought home a Macan 4S - Colorado. I'm using a Tesla Wall Connector on a 60 amp circuit with a TeslaTap 50 amp adaptor. Both wall connector and Macan show 9.4-9.5kW. The model Y I had previously charged at 11kW / 48 amp.
I guess I'll have to get used to 15% longer charger times
ChrisFromUK
My belief is that the Macan 11KW inverter is limited to 9.6KW per electric phase.
So at charging sites with 3 phase electrics/chargers you get close to 11KW charging on the Macan.
At charging sites with single phase electric/chargers you are limited to 9.6KW even if the charger can supply 11KW or higher.
In the UK, the Porsche Technical Data is explicit that 11KW charging is possible:
"Charging time (AC) at 11kW (0 - 100%) 10.0 h"
In the USA configurator, this statement is not present in the technical specifications, possibly because there are relatively few locations where 3 phase electrics/chargers exist.
3 phase electricity is not a thing in North America for EV charging - the North American J-3400/J-1772/CCS1 standard does not even have the necessary electrical connections to support 3-phase being delivered to the vehicle - the only way 3-phase power is "supported" would be via a DCFast charger - where the DCFast charger is being supplied 3-phase AC power but delivering DC power to the vehicle via CCS - bypassing the onboard AC/DC charger on the vehicle (note to self: most DCFast chargers in North America probably are served by 3 phase power ;-) - but the AC power source doesn't matter once it's converted to DC power).
I would find this explanation viable except for one thing: The Taycan charges at 11 kW in North American, and so do the new 2024 Cayenne Hybrid's and so does the Audi eTron's (I haven't had access to a Q6 in North American)
I find it implausible that the Macan is the one product in the VW/Audi/Porsche line up that has a different AC/DC onboard charger…
I still believe it's a "setting" inside North American Macan's - that is the result of some confusion by Porsche between the limits of mobile EVSE's in North American (i.e. the one the vehicle ships with) which is 9.6 kW, and the actual limit of 11 kW which requires a hardwired Porsche Wall Charger or similar…
but proving that is going to be difficult.
ChrisFromUK
Interestingly, the Porsche Configuration Technical Data for the USA only states 9.6KW charging for the Taycan too whereas in the UK they provide times for 9.6, 11 & 22KW.
Right now, Porsche seems to be making no claims for anything greater than 9.6KW charging the the USA for either Taycan or Macan. In the UK, they are definitely claiming that both Taycan and Macan can do 11KW and that Taycan can go to 22KW.
I wonder why there is a distinction in the Technical Data between the USA and UK/Europe.
That said, I do hope that Porsche will investigate as it does seem unreasonable to be limited to 9.6KW.
here is standard equipment list for Taycan in USA configurator right now…
Electric Macan EV [Poll] - Porsche charging specification lie?  Macan is not allowing 11 kW max charge rate - capped at 40 amps? 9.6 kW max rate. IMG_2445
here is Macan's standard equipment
Electric Macan EV [Poll] - Porsche charging specification lie?  Macan is not allowing 11 kW max charge rate - capped at 40 amps? 9.6 kW max rate. IMG_2446
and here is Cayenne Hybrid
Electric Macan EV [Poll] - Porsche charging specification lie?  Macan is not allowing 11 kW max charge rate - capped at 40 amps? 9.6 kW max rate. IMG_2447
Panamera eHybrid
Electric Macan EV [Poll] - Porsche charging specification lie?  Macan is not allowing 11 kW max charge rate - capped at 40 amps? 9.6 kW max rate. IMG_2448
NOTE: how the Cayenne lists the included charger at 11 kW - which is:
  1. Impossible for a mobile EVSE in North America
  2. the exact same EVSE included with Taycan & Macan
Porsche is deeply confused about all things charging in North America and has been for a quite a while - they can not get straght the difference between:
  • maximum charge rate of mobile EVSE's in north america (40 amp 9.6 kW)
  • maximum charge rate of the onboard vehicle charger (11 kW standard across the fleet)
  • maximum charge rate of any EVSE in North America (80 amps 19.2 kW)
even though they sell a Wall mounted hardwired EVSE that can provide 19.2 kW or any amount between 12 and 80 amps since it's adjustable…
it's been confirmed with actual North American Porsche products that:
  • the Taycan can actually charge at 11 kW factory stock
  • the 2024 Cayenne can actually charge at 11 kW factory stock
  • the 2024 Panamera can actually charge at 11 kW factory stock
  • the 2024 Macan EV is capped at 9.6 kW
I'm thinking software configuration error in the vehicle's "settings/codes" - and changing this setting would "unlock" the 11 kW charge rate - this is no different than Matrix LED headlights being neutered in North America as Porsche does not yet ship them with the Euro-partial high beam functionality - and changing the "coding" in the ECU "unlocks" the headlights in North America...
wanna bet there is a setting in the Macan ECU/vehicle-codes for max charge rate to match on board hardware? and someone insideof Porsche got confused by the 9.6 kW _MOBILE_ EVSE limit of 9.6 kW?
ChrisFromUK
That's the Standard Equipment list but in the Technical Data section (Macan EV) for the USA it states:
Electric Macan EV [Poll] - Porsche charging specification lie?  Macan is not allowing 11 kW max charge rate - capped at 40 amps? 9.6 kW max rate. 1734283501829-1v
But for the UK Configurator it states:
Electric Macan EV [Poll] - Porsche charging specification lie?  Macan is not allowing 11 kW max charge rate - capped at 40 amps? 9.6 kW max rate. 1734283614257-ci
There are similar differences for the Taycan.
Why has Porsche removed the 11KW charge rate timing from the USA specs?
alvaro
Álvaro
ATL, GA Metro - USA
This is a bummer. I wanted to upgraded to an 80A charger (just because, I guess) but it looks like it won't have any real effect.
That would be a waste to have 80Amp circuit if you plan to charge the Macan. I would still go for the 60Amp as hopefully some firmware update will allow Macan hardware to accept 48Amps in and charge at fully advertised 11kW. However, so far it maxes out at accepting only 40Amps regardless of higher powered EVSEs.
bergs
Pete
Woodside, CA
'22 Taycan RWD, '24 Range Rover LWB, '18 Model 3
I'd imagine its a software limitation in the OBC. My taycan previously charged at 11.5 kW with a 60A chargepoint home, and now its only getting 9.6 kW input (8.8 kw into battery) after a software update
Received an email from Porsche highlighting the new charger:
“Porsche Fast Charging Comes Home”.
Not sure it’s worth it considering that the Macan cannot charge at more than 9.6kW…https://shop.porsche.com/us/en-US/p/porsche-wall-charger-connect-9J1068209-B/9J1068209
yeah, i saw this comm today....and it just made me wonder if the comm was generic to other vehicles or to regions where some super power is available...
Cuz the Comm says 19kWh....and all of the Macan documentation says 11 right?
EdInSanDiego
San Diego
I suspect people just aren't aware of their charger's limitations. Like, my 8-year-old charger at home is rated for 32A continuous and is 240V of course. 240*32 = 7.7 kW. So, for me, it makes no difference what car I'm charging because it would never be able to charge at more than 7.7 kW unless I replaced my level 2 charger.
In order to charge at 10.8 kW with 240V, the charger would need to be rated for 45 amps *continuous* (not peak). Which very few are.
