ppcarter1
paul
uk
macan 4, id3, defender 90
Crap............rattle/clunking is still there. Guess it wasn't the misaligned tailgate. Of course my SA told me the tech never heard the sound, which boggles my mind. Guess it will have to go back for further analysis to figure out what's causing it and what the fix is.
Please see my previous answers about what the problem was. It is the latch rattling around. Still waiting for the dealer to sort, but packing out the latch has saved my sanity in the short term
Electric Macan EV Annoying rattle/knock when going over bumpy road IMG_8312
Guys,I think there's a great chance the solutions described by both @ppcarter1 and @Jetced be related.When the 2 so called “distance holders”/regulators are extended won't allow the locking latch mechanism become loose, hence the rattle noise.When the hole trunk door locking is stiffened extending the 2 regulators the rattle stops.By wrapping the latch you get exactly to the same point
Seems quite logical to me. ?
JerShanMan39
Jeremy
Toronto
2024 Porsche Macan EV Turbo
Do you have to pack it like that every time you open and close the tailgate or does the wrap somehow stay in place?
ppcarter1
paul
uk
Its just kitchen towel tightly wrapped around the metal.
Felix2019
Macan 4 EV, 911 4S
My trunk lid was rattling also. I unscrewed the black stoppers as far as they would go without falling out on both sides. This solved my rattle.
Electric Macan EV Annoying rattle/knock when going over bumpy road IMG_0584
Electric Macan EV Annoying rattle/knock when going over bumpy road IMG_0583
Obviously the issue deserves the "solved" stamp in the issues list thanks to @ppcarter1 who discovered and proved what was the cause and @Jetced who discovered the proper and professional way to approach the solution???
Shane M
Shane
NY, USA
Macan 4 EV
Could folks provide more feedback on the two methods (added layer of wet paper towel and adjusting the distance holder) vs. the trunk lid rattle?? Because our rattle is still present (although less than before with these methods.
henrus
Henry
Bay Area
Adjusting the distance holder works. But I had to unscrew both of them pretty far out. I unscrewed each completely out first, then screwed them back in a couple of turns and that finally killed the rattle. Your mileage may vary.
ppcarter1
paul
uk
i also have removed the parcel shelf. I have extended the distance holder as far as possible and wrapped insulation tape around the metal bracket. No rattle at all now
Shane M
Shane
NY, USA
Macan 4 EV
Could you attach a photo here with the insulation tape, with which I assume you replaced the paper towel. Thanks man!
Shane M
Shane
NY, USA
Macan 4 EV
I will try and play with my distance holders again like yours; what do you mean by "your mileage may vary"?
henrus
Henry
Bay Area
I simply meant that how much or little you screw them back in may be different for your car. For me, I found two turns to be perfect, and I've not had any issues since then.
Shane M
Shane
NY, USA
Macan 4 EV
Gotcha! We tried adjusting the distance holders several times in different ways, but have not unscrewed them very far out yet, worrying that might affect how the trunk lid closes. So the rattle noise has only got better but not disappeared yet. Thanks for the tip!
henrus
Henry
Bay Area
Yeah, I was concerned they might fall out, but I was able to do 2 turns and they are secure. Saved me a trip to the dealer. I'm guessing at some point they may do something that's a better fix, but for me, I stopped thinking about it now.
