- First Name
- David
- Jan 28, 2019
- Santa Cruz
typically the car ignores voltage and managed amps/current…both the PMCC and the Tesla Gen3 Wall charger show "amps flowing through" it during charge session - and 40.7 seems to be the value my Macan pulls…which is odd - it should only pull 40 amps or less when it's talking to the PMCC since PMCC reports 40 amp maximum - all othre EV's using the PMCC pulled less than 40 amps - typically 39.5 or 39.7 amps or something like that…I wonder why both of my ChargePoint Home Flex's set to 48 amps on 60 amp breakers have never reported more than 9.4kW to the Macan (that I've observed, anyway). The Macan itself typically reports 9.1 kW on these EVSE's. I wonder how you've gotten to 40.7 amps. Unless, possibly, under voltage so higher current to make up for it e.g. (although that's not how it should work, should it? What should the car be limiting: current or power?)
