can anyone explain why the window sticker says 11.5 hours recharge on 240v ?
that sound about right? it still depends on the amperage, right?
Does sound about right and probably based on the Macan’s ability to only absorb 11A from a level 2 charger.
About the same amount of time for my iX which also can only receive 11A from a level 2. Of course that 11.5 hours assumes a 0% SOC when starting out.
route128
Joe
NH ??
2024 Macan EV Turbo
The numbers are lower than anyone expected or wanted.
Also it is dependent on the weather (temperature) and tire size and driving style.
I wouldn't say that. The EPA numbers were always going to be less than the actual range, the EPA is quite bad at measuring EV range.
We already know from real world tests that the 25 Taycan is outperforming the EPA rating consistently, and the earlier Taycans vastly outperformed the EPA.
Basically all this means is given decent conditions and normal speeds the range floor for the Macan 4 is probably the 308. That can drop given specifically cold weather or prolonged high speeds (75+) but I expect most people will see more than 308 miles most of the time.
As for the Brazil numbers, they made me laugh. They're nonsense.
route128
Joe
NH ??
2024 Macan EV Turbo
On my Tesla I have never reached the EPA rated range. Hopefully Porsche is the opposite.
The local Porsche dealer GM responded
My Taycan shows 192 on the sticker and I get 255-298 max It’s really based on the driver and how it’s driven. I can drive it like a maniac and get only 150 miles to a full charge.
I wonder how many speeding tickets you would get at that rate ?
When I want I will get tons of range. I would not be surprised if even in the Turbo with 22”’s that when we really need, we will get around 310 miles range. But with planning ahead, even with road tripping there have been so very few times (maybe two or three) that we needed more than 275 miles to get comfortably from here to there
When I play, of course fun overrides all range considerations.
rpbrazil
São Paulo, Brazil
Macan Turbo EV
It can absorb 11kW which is 240V x 48A single-phase.
My home charger is 3-phase 380V 16A. Also delivers the same 11kW.
Rocket Roger
Roger
San Francisco Bay Area
98 Audi A4 2.8 Quatro 5Sp, 2018 Audi A5 Spt Bk, Niss LEAF, Yam XSR, Macan 4
I saw this note on Test cycles on page 17 of the EPA Test Data. The note states Porsche chose to test these at 55 mph and not 62. If this is what they did then the stated range is higher than what it would be at 62 mph, which is the normal test speed. Comments?
"Test cycles: Porsche chose the Multi-Cycle Test (MCT), following SAE J1234, 2017 version. This means that the constant-speed portions were run at 90 kph (55 mph). The total test sequence is represented by the chart below, except that the constant speed was 90 instead of 105.
For the California highway portion, Porsche used the "Highway All-Electric Range Test for Battery Electric Vehicles" per California Code of Regulations (CCR) title 13, section 1962.2 (F) 3.2.1. Therefore, the range and energy consumption values shown in Section 17.08 combine this California-only cycle and the UDDS portions of the MCT."
Very good catch, though I am not concerned for we saw the videos of both Edmunds and OutOfSpec and they each got over 300 miles at 70 MPH — one with a Macan 4 and one with a turbo. Two other respected EV range testers, such as Thomas@Autogefühl also commented that they expect just over 300 miles.
quaxon
San Francsico
Anyone else somewhat disappointment? This is going to be my first EV and one of the things that drew me in was the Porsche estimated ~380 mile range.
Where did you get that 380 mile estimate from?
quaxon
San Francsico
