Question on regen …
Never mind the wording, Porsche should correct it. But more interestingly, it would be nice to know if everybody who is interested in doing a comparable test to really get to the bottom of this … almost 6% more efficient is nothing to sneeze at …
Life is too short!
So here's an interesting change.... I just took the car to the gym, and i noticed i had no braking regen....
Battery was about 56*f, outside temp is 32*f.... Battery is about 66% charged....
So I'm very curious as to why the car would turn it off. I'd i turned on the "thrust regen", it would happen as usual, even during braking. But with regen off, i had 0 regen on the brakes
Is this a weather dependent thing?
Which instrument dial shows regen? Do you have a picture?
the middle tube with the speed...where the dial goes green or blue.
The car relies on friction braking if the battery is unable to accept a charge, either because it's full, too hot, or too cold. But I would have thought that at 56F you would still get regen.
that's exactly why i was noting the temperatures. the car is garage kept, so that's why the temp was that high when it's actually snowing out...
Now on my way home from the gym, I had regen. The battery was about the same temp...the only difference is now the car sat in the cold for a while...
The only thing i can think of, is that the car wanted to "warm up" the friction brakes...yet, they would have been colder on my way home, when i had regen
Weather (cold) will be a factor for sure as will standstill time.
sarinotropeano
Sarino
New Jersey
2024 Macan 4 EV
I set up the regen as my custom steering wheel button. I only use it in city driving. I definitely agree that coasting is more efficient especially at highway speeds.
my last car- Etron had paddle shifters so I had the option of two levels of regen. What I found was I enjoyed the ability to manually choose to “downshift” and I had over 90,000 miles on the car and never needed brakes replaced.
with the Macan I heard the regeneration occurs through the brakes and I do notice the dial going into the green so I believe that is true. And when I hit the brake pedal am I using the brakes or motor regen to a certain point before it uses the brakes?
I am also seeing is quite a lot of brake dust on the rims. So I am expecting that brake pads will need to be replaced similarly to an ICE vehicle.
any thoughts about that?
Depending on conditions your car will use the motors to slow down if you enabled recuperation. This method is known as overrun recuperation and simulates engine braking in a mon EV.
Using the brake pedal and depending on how hard you press the pedal the discs will also come into play (e.g. early days of ownership and heavy / emergency braking) will also use the motors to slow the car down (after the first mile or so driven).
As this is a new car with few miles on it then the discs will be used more and hence the presence of brake dust. After 700 or so miles this will change and the motors will do most of the braking.
The green bar shows when either overrun or braking recuperation is active. Braking adds more energy back than overrun.
LivingTheDream
Thomas
Greater Boston
Macan 4S 718 Boxster
Another factor is your state of charge. Regen can only occur if the battery can accept the juice. If you are at a high state of charge, the battery cannot accept the energy and hitting the brake pedal will use the brakes instead.
sarinotropeano
Sarino
New Jersey
2024 Macan 4 EV
Because of the excellent range of the EV I seldom charge over 70%. So I know that it is capable of regen.
My EV will one pedal regen when indicating 100% charge, driving off from the charger. Its got a small battery so I routinely charge to 100% indicated. But that is probably not actually 100%. I suppose you could use up the 100%+ buffer eventually and loose regen.
Not sure that's the case. When HV battery has a high state of charge recuperation is (logically) limited and the energy lost as heat. This does not mean that the motors don't provide braking and only under emergency braking would the rotors come into play.
It will show recuperation is active but won't be adding energy back into the HV battery given the high state of charge.
Wait: I'm not arguing, because I genuinely don't know, but then something must be converting the electrical energy to heat. What would that be? Meaning: the motors would be resisting movement by generating electricity; that electricity needs to go somewhere. Where, if not the battery?
Air
