These are not actual issues with the car though - they are more annoyances or a wishlist of features you’d like to have.My biggest issues/feature-requests, which are mostly software related save for one:
1. wifi connection from a mobile phone inside the car is terrible. this is after disconnecting from carplay obviously. i have to hold my phone outside the car through the window to get a signal. usually there is an antenna in the interior of most cars that help with this, but I don't think the macan has it for some reason.
2. parking assistance camera doesn't go away immediately after shifting to drive from reverse (small 3-5s delay). exiting via the X in the top left corner can make it dismiss immediately though
3. we need a play/pause function for the quick access button on the steering wheel.... otherwise just stuck with muting via clicking scroll wheel or volume knob. even better is if we can replace muting with play/pause
4. we need a lane assistance toggle for the quick access button on the steering wheel...otherwise it's unsafe to toggle it off via additional functions under the assistance tab of the car settings (3+ taps on the middle screen to navigate there)
5. apple car play doesn't show google maps on the front monitor. wish it did. it would be extra cool if the AR HUD could relay directions from google maps as well.
Some minor stuff:
1. wish there was a way to turn off all lights when parked without having to lock the car and potentially trigger the alarm if touching something from inside
2. owner manual needs to show location of fuse box for those of us that don't want to opt for installation of the porche dash cam and want hard wiring access
that's all I can think of aside from a few other things I want to make sure aren't the result of user error. it's a really great car.
@Diego Eng=control freak. : )As @tmrqs wrote it would be better to maintain separate issues (things broken or that should work in a different way) from improvement.
I’m sure that Porsche is monitoring (been advised by my dealer) EV forum and FB EV pages to get feedback and it would be great to organize also these improvements in a categorized thread (yes, I’m an engineer)
this https://shop.porsche.com/us/en-US/p...rest-key-ring-P-WAP0503570RCHS/WAP0503570RCHSWhat card and rfid key ring?
I'm 1500 miles and 48 hours into a road trip - I've experience only _OINE_ of these issues - which is trouble charging at EA FastDC chargers - 99% likely this is not a problem with the vehicle - rather EA is a well known sh*t-show and has been for years…I await the opening/access to the Tesla Supercharger network so that I never have to use a crappy EA charger ever again for my travels.If it would be helpful, I would like to collect in this discussion records of problems described by users up to the date given in the title:
Area / thread link Issue Region User Cause Fix Air Conditioning no cooling is provided. US No freon installedAir Conditiong / vents passenger side floor vent / flapper doesn't close US TBDClimate Control Button button intermittently don't work when the car is powered ON US TBDSatellite Radio connection lost US TBDElectric charger port cover passenger port works randomly US Sensor out of positionOwner's Manual in PCM No Contents are available in PCM US TBDInstrument Cluster instrument cluster does not turn on (display blank / dark) Canada @dmd TBDBlind Spot Monitoring Blind Spot Monitoring not working US TBDAssistance Systems Error - Speed Limit Display (Warning Message) Intermittent fault messages displayed on instrument cluster UK TBDAssistance Systems Error - Speed Limit Display (Warning Message) Adaptive cruise went out US TBDLoud buzzing sound from mirror area After triggering the front collision warning system there's a loud buzzing sound coming from the upper mirror area (cameras/sensors just below the mirror) getting worse pressing the plastic cover EU TBDCar restart solved Front (air) suspension cracking Cracking sound from front (air) suspension when driving slowly over speed bumps EU TBDDC Charging Issue Due to Software Glitch DC charge at an Electrify America terminal - no success. USsoftware glitch Bose sound stopped working Only two front speakers works no matter what I do, reset pcm EU
TBDCompass intermittent function sometimes compass works properly and sometimes it does not US@dieterf TBDTrunk emergency release error Vehicle sounded alarm and displayed warning message while parked in garage Canada @shawn Unknown Alarm stopped on its own after 10 minutes and trunk operation is normal Smoke and burning smell from air vents Burning smell and smoke from air vents when driving 130 km/h (80 mph) or higher, with or without the climate control on EU@piter95 TBDRotating Random Sensor Alerts Series of rotating random alerts that keep cycling US@GaryV TBD
Please consider this thread as a glossary thread, which links to individual reported issue threads (where everyone can reply and comment). If you have an issue, please create a new discussion thread for it and it will be added to this list.
Thanks for your detailed diary @daveo4EV, there's a lot to learn and it's a different test than my 5500 km in a month. I think too that what you had it's more a problem with the charge infrastructure than with the car itself. In 3 years of superchargers with my previous Tesla I never had a single issue so it would be great if you in the US could use the Supercharger net as it's possible in Europe (even if, as @byebye wrote, with some charging limits).I'm 1500 miles and 48 hours into a road trip - I've experience only _OINE_ of these issues - which is trouble charging at EA FastDC chargers - 99% likely this is not a problem with the vehicle - rather EA is a well known sh*t-show and has been for years…I await the opening/access to the Tesla Supercharger network so that I never have to use a crappy EA charger ever again for my travels.
EA never gives me more than 150 kW - so honestly there is no "faster" charging network in North America - and I'll lose less time at the superchargers having to try multiple stalls to find one that works…Problem with Tesla SuC <v4 is that you are going to charge at a maximum rate of 135 kWh, because it delivers only 400v.
It will add 10 minutes to the 10-80 charging time.
