Several errors at startup clear after 5 minute shutdown, anyone else?
ExVolt
Rick
Sf
I know at least one other forum member has experienced seeing a series of error messages at start up (and the car won’t start):
- Engine control error, park vehicle safely
- Please charge battery
- Charging not possible, visit workshop
- High voltage system error, service required
After locking the car and waiting a few minutes, we can restart the car with no problems.
Obviously, these messages are spurious given they disappear after a 5 minute shutdown. It’s some software bug, not mechanical catastrophe.
Has anyone else besides Yves and I experienced this? If so, do you just live with it until such time that Porsche issues a patch? Or are you scared to take it on long trips?
Software glitches as per Taycan
I had 3 “false” warnings in the first 500 km:
  • Main battery error
  • Front headlight lamp error
  • Car too low.
Both vanished after a close / wait 5 minutes / reopen cycle.
Since then no other error (and I’m at 6600 km).
Senna
Leo
Austin, TX
Audi SQ7, Macan 4
I haven’t encountered this issue. My Macan 4 has 2,162 miles.
RunningOnSolar
Scott
Ohio
Macan 4, Subaru Solterra
I have not seen that error either after 1500 miles, but have seen another charging error. It happened after I took the car out and plugged it in on return. I got an error that showed up as “Charging not possible precool heat” in the PCM. The error also showed up as red lights on the charger. I suspect preheat does not clear if you take the car out before it completes. After disconnecting and unplugging the charger. I was able to remedy this and charge the car.
Also noticed that a preheat restarted the morning after I used it without a schedule when I opened the app. I had to manually deactivate it. Watch this feature carefully to make sure it is behaving properly if you decide to use it
ExVolt
ExVolt
Rick
Sf
  • Car too low.
Thanks so much Diego (and Yves). Given you both have had similar experiences to mine, I'm going to assume my errors are "gremlins".
So, I will retrieve our car from the service on Monday and take it on its first road trip down the California coast (with our bikes on the back). The weather is going to be glorious next week and I can't wait to finally see what the car can do.
We have to return the car to service on Dec 9 to replace the failed tailgate motor as it should have arrived from Germany by then. If they want to hunt for the gremlins then, they can.
And thank you for sharing the "5 minute cycle". It has brought me some relief as I was beginning to think I had purchased a lemon. I'm a bit surprised my dealership didn't know such a simple trick.
piter95
Pietro
Czech Republic ?? (from Italy ??)
Macan 4 (EV)
I did actually got the same you had on the first day, second drive when I picked up my new car.
Never happened again. I did also a factory reset through the infotainment system… I don’t know if that helped.
I'm saddened to hear this - but unsurprised it clears after a bit - all my Porsche's have momentary "faults" that clear themselves - it seems endemic to the brand - I have similar "faults" with my Taycan, 911, Cayenne - I've learned in years of Porsche ownership to ignore faults until they "persist" - most of the time they are transient - also if the car is allowing itself to be "driven" it's also not that bad - if I have faults but it's not affecting my driving I simply note for the next time I'm going to service, rather than schedule a service visit…
modern cars are a maze of mulitple computers talking to each other - faults are generated when they can not see/speak to each other - sometimes these are just temporary race conditions in start up conditions where all the computers are waking up all at once and overwhelm the can-bus with too much chatter … so they report that they can't see their peer computers - but by the time they generate that report everything has quiesced and is working fine "now"…
so far knock on battery-wood - my Macan "faults" have been minimal an nothing to be concerned about, and have cleared themselves.
ignore the faults until they persist…normally they won't persist…that's been my experience.
@ExVolt Have nice drive and ride Rick (with a lot of envy for your drive along the CA coast... I have to wait another 1,5 month before I can be there....)
wmras
Oregon
Every Porsche with a PCM system benefits from being locked for 15 minutes with no key within 30 feet, even in your garage. The vehicle clears system errors if it sets locked and away from nearby keys or activity. We lock all our Porsche vehicles when we arrive home and keep the second key in a RFID shielded pouch (it is in my wife's purse).
In our 2020 Taycan Turbo S, we once had a major electrical failure with instructions not to drive and call service. We think a stranger's partner was trying to hack into our car while the stranger was asking a lot of questions about the car. We fixed the major electrical failure warning problem by locking the car (with us inside), placing both keys in the RFID pouch, and waiting 15 minutes. Took out my key, started the car normally, and drove home without any issue. That was four years ago and the Taycan has never repeated such a failure.
Bottom line, lock the car when you are not using it and keep keys away from it.
ExVolt
ExVolt
Rick
Sf
Yesterday, after we'd been on the road for about 45 minutes in ACC, we were presented with a message in Tube C indicating "assistive systems were not operational". The cockpit showed 3 errors that were new to me: 1) cruise control was not operational, 2) the system that monitors if the driver is responsive was non-operational, and 3) the collision detection system was non-operational.
Tube C said we could keep driving, so we did. Had lunch. Got back into the car and noticed the errors persisted. We'd resigned ourselves to another trip to service. Then, after 5 minutes of driving, the errors all disappeared and we could use ACC again.
To date, we've been treated with single viewings of many of the monitoring errors available in the Macan EV (I've seen ~ 10 different errors). Fortunately, they go away after turning the car off for a bit. I know other members have witnessed this behavior but I wondered how prevalent this is. Curiously, when I look in the manual, many of the errors have a description that says something like, "should the error persist, get service". Almost like the engineers knew the error might just go away on its own most of the time.
Guess I gotta be content that the messages eventually go away on their own, but it's still a bit unnerving. BTW - the icon used to indicate the system that detects if the driver is non-responsive is "one for the ages".
This is our only complaint with the car. Besides these error gremlins, the car is fantastic.
jawson
Jonathan
England
Macan S
I’m currently sat in mine. As just went to start and it’s lit up with all the errors above.
waiting five minutes to see if it’s ok.
And have Porsche assist on the way.
jawson
Jonathan
England
Macan S
Ok waited five minutes and it’s all working - all errors gone
The classic have you turned it off and on again.
Not ideal. But at least it sounds typical software! Was just a little discerning and thankfully not in a rush.
Electric Macan EV Several errors at startup clear after 5 minute shutdown, anyone else? IMG_7061
So my car is at the shop for another issue (suspension cracking over speed bumps) but I've also had these random errors and turns out there is a software update they are applying that is supposed to fix this. We'll see, don't know any details. Is there a way to check the software version? I know you can check the PCM software version but I guess this is not it.
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
this happened to me after i air dried the car. Walked away 1-2 min and all went away.
