I just did a factory reset and stayed as guest account, then attempted to charge to no avail. The charger would click and it would go from green to yellow multiple times, I think I counted 5 times before it fails permanently and goes red.
I am sorry, definitely a very frustrating problem. I see you have tried almost everything. Not a bad idea to bring a car to your home to see if it charges. If so, then the problem is with your vehicle. If it doesn’t charge then maybe with the charger or your home. One last thing, maybe check the charger error messages in the Owner’s Manual to see if it helps pointing you in the right direction: Owner’s Manual > Charging equipment Owner’s Manual > Porsche Mobile Charger > Operating manual > Chapter Overview > Operating unit status indicators and error messages
lukine
Inez
Yea I did read about charging error from my Porsche app, and the error message tells us to check the infrastructure, which I already did by hiring electrician to check. So at this point it seems like the issue is either with the car, or my home. But I'm leaning towards the car more so than the home as I'm not the only person experiencing the charging issue after an update. In order to eliminate my home as a possible cause, I'd definitely need to bring another car to charge at my house. Preferably a different make.
Dragon Tourniquet
Nevada
Long shot, but is the frequency of the AC power somehow wrong in your house? It should be 60Hz +/- 3 (5%).
Bolt1323
macan 4
Highly doubt that Porsche tech came with a 2024 Macan turbo was were able to charge try my Macan 2025 Macan 4 wasn’t able. I also have been to multiple houses and yet to find a house that my Macan charges at after the software update.😖
lukine
Inez
I don't have the expertise or the equipment to be able to do this. I'll just assume the electrician that came would have probably checked that as part of the checks. And if he didn't, then it may be something he didn't think would be relevant.
I tried using Gemini AI to see if it had any insight we haven't considered or talked about yet.
This is what it said:
Electric Macan EV MY26 software update (week 36) for MY24-25 1768239912344-m2
as other cars included other macan can charge at your house it must be the car. macan are able to charge nearly anywhere.
lukine
Inez
Latest update on my case, I found out one of my neighbours owns a Taycan and a Tesla X. She brought both cars over to test charging and both of her cars charged at my house using my Porsche Mobile Charger. It’s just my car that won’t charge.
FirstEV
FirstEV
Sweden
When I had issues charging at home the decision from Germany was to change the high voltage charging system that is placed below the rear seats. That fixed all the issues, they diagnosed it over night and sent the info to Porsche AG. This is pretty clear to be a smiliar issue. I am flabbergasted by the incompetence at many dealers around the globe.
lukine
Inez
Wow, I feel like dealerships in NA need better technicians then. Because everything that has gone wrong with my Macan, they've blamed on software. My backup cameras went black a couple of months ago. I had to take it back 3 times before they finally decided, oh it's the surround view cameras' module that should be replaced. Initially they kept resetting it, and it would work for one drive home, and go black again the next morning. I have had issues with Carplay not connecting since I took ownership of the car, and all they do is reset stuff, or blame on software glitch, and they make me wait for the next update to "fix" the problem. There were also random error messages popping up, some reds, some yellows, but when dealer downloaded the codes, they said they're inactive and they can't find anything wrong. So then they tell me to wait for the next update to "fix" the bugs in the software.
lukine
Inez
I'm curious, did your vehicle have any faults when they diagnosed that the problem was the high voltage charging system?
Because when I asked them if this could be the culprit, they said that when they scanned my car, there weren't any charging system errors. So they can't do any tests to verify if there are no faults. I have an open ticket with Porsche Canada, and they escalated my case to a regional PCIC Case Specialist who is supposedly working with my dealership on a solution. But this doesn't sound like they're dealing with Germany's Porsche.
FirstEV
FirstEV
Sweden
No faults at all except yellow warnings from home regarding Ac-charging but nothing they could see.
Just a heads up regarding my dealer: The dealer involved is one of only two in Sweden authorized to carry out Manthey kits, so a lack of competence or basic diagnostics isn’t the issue here. According to them, they did run diagnostics locally, but the specific data related to the high-voltage system is not something the dealer is authorized or able to fully interpret on their own. That’s why the diagnostic data was forwarded to Porsche AG in Germany.
This wasn’t an isolated situation either. Before the repurchase, my car had multiple faults, and the same workflow was followed almost every time: local diagnostics, escalation to Porsche AG, and only then a decision on whether hardware should be replaced or not, even in cases where no clear fault could be confirmed at dealer level.
My head of service was also very clear that Porsche AG did not provide any detailed technical feedback beyond instructing them to replace the component. They couldn’t confirm whether there was a confirmed defect, only that the replacement was mandated from Germany.
So to be clear: the absence of visible fault codes at dealer level doesn’t necessarily mean that an issue is ruled out. In these cases, the interpretation and final decision sit with Porsche AG, not with the local dealer and that’s exactly how this case should be handled.
MyA
Marc-Yvon
MontrĂŠal, Qc, Canada
Taycan 4S, BMX X3, Golf GTI
Out of curiosity , Where are you located in Canada?
MyA
lukine
Inez
My dealer is still in the stage of ruling out external influence (meaning my home's infrastructure), and apparently they still don't have enough data to escalate to Porsche AG. They wanted to send an electrician to install a device to lower the voltage from 240.2 to 240 and below to see if it charges. But my husband doesn't want them messing with our electrical system when he knows it's not our house that's the problem; proven by the fact that other cars (Taycan and X) are able to charge at our house. So right now, it's a waiting game for me because they're going to try another client who is having the same issue as me and they're going to send electrician to her house if she's okay with it. It really sucks when their local diagnostic process is so slow. They literally sat on their butts on this until I called Porsche Canada to complain.
I'm having the same issue with our new Lucid Gravity. The Grizzl-E I've had for 5 years charged our Mach-E just fine, and charges our Macan just fine. But faults every time I plug in the Gravity. So I tried the mobile charger that came with the Gravity using the same 240V outlet, and it works on the Gravity. I also tried the the Porsche mobile charger and it works on the Gravity too. Everything works with everything else except the combination of the Grizzl-E + Gravity.
Strange.
